[Fwd: Re: WFS gurus . . . .]
Bob Basques
bob.basques at CI.STPAUL.MN.US
Tue Jun 6 12:32:51 EDT 2006
Frank,
This is exactly what we we're looking for.
I guess we just needed to dig far enough to get our terminology right to
ask the question(s)
Thanks
bobb
Frank Warmerdam wrote:
> Bob Basques wrote:
>> All,
>> Some progress,
>> We've managed to add to the PROJ4 EPSG list and verified that it works
>> with a WMS output. So the new EPSG code we added works just fine as a
>> WMS call.
>> Next we tried the same with a WFS call and got an INIT error, which was
>> traced to OGR, so we then (tried to) build Mapserver without GDAL only
>> to learn that WFS requires it to build. So my question is, where is OGR
>> grabbing it's Projection info from? From the code it looks like there
>> is a parser in place, but we couldn't find where it was being referenced.
> Bob,
> OGR creates it's EPSG coordinate system information from the pcs.csv and
> gcs.csv tables distributed with GDAL. Note that periodically these
> tables are regenerated from the EPSG database, and these .csv files are
> the basis of generating the PROJ.4 epsg translation file.
> In theory you can extend the pcs.csv with your projections but the format
> is a bit esoteric.
> I believe you can add Well Known Text format definitions to the "epsg.wkt"
> file in gdal/data to add stuff not in the pcs.csv and gcs.csv files though
> I haven't used this mechanism for a while. This is what I use to add
> Cubewerx and ESRI extensions to the EPSG dataset.
> See gdal/data/cubewerx_extra.wkt for examples of how the definitions would
> be formatted.
> Best regards,
