ogr connecting to .tab files
Donal Regan
donal_regan10 at YAHOO.CO.UK
Thu Jun 8 20:26:30 EDT 2006
Hi Frank,
Thanks for the reply.
What I have is a load of .tab files with corresponding .TIF files. The .tab files have Type : "RASTER" in the definition table so I presume that means they're not supoorted. Does this mean I can't use them as a Mapserver datasource at all? Or can I convert them somehow into a format supported by Mapserver?
Thanks,
D.
Frank Warmerdam <warmerdam at pobox.com> wrote: Donal Regan wrote:
> If I do ogrinfo or ogr2ogr on my '.tab' files , I get the following error
> Unable to open datasource `../jmc25kRaster/' with the following drivers. etc
> Error
Donal,
Is it possible that your tab file is really a "raster tab", that is a .tab
file describing a raster file, rather than part of a vector dataset (usually
a .tab, .id, .map and .dat)? If so, you are out of luck as OGR (nor GDAL)
support .tab labelled rasters.
Best regards
and watch the world go round - Rush | President OSGF, http://osgeo.org
Send instant messages to your online friends http://uk.messenger.yahoo.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060609/95229f6b/attachment.html
