fontset tag kills map
Robert Burgholzer
rburghol at CHESAPEAKEBAY.NET
Fri Jun 9 09:36:22 EDT 2006
Well,
"die" means, it just stops working, I get a [defunct] for the process in
my 'ps ax'. I managed to debug it though, through the use of the mapserv
CGI, for some reason I was unable to get any error messages via PHP
mapscript (this is an entirely new server install and I am migrating
from the old -- I would have sworn that my documentation of
configurations was impeccable, but, it turns out not to be so).
So, it was a simple thing, the fontset was inadvertently duplicated (an
errant paste a few lines down).
It is strange that I am getting no error messages though, although if I
RTFM more thoroughly, I will probably figure that out.
r.b.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Doyon, Jean-Francois
Sent: Thursday, June 08, 2006 4:02 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] fontset tag kills map
Also, is this one particular font, or all of them?
Behalf Of Steve Lime
Sent: June 8, 2006 3:57 PM
What does 'die' mean? Seg. fault?
Steve
>>> Robert Burgholzer <rburghol at CHESAPEAKEBAY.NET> 6/7/2006 10:52:40 AM
I am trying to use labels in mapserver 4.8.3 but even defining a FONTSET
tag
in my map file kills the initialization of the map in php_mapscript.
I can have a label layer, as long as it is OFF, but the minute that I
put a
FONTSET tag in my map file, or turn the layer ON, it dies without error.
Fonts are in the directory in question and have permission 744.
Any ideas as to what may be the trouble?
PHP is compiled with freetype support, as is mapserver:
Below is the message configure gives:
configure: checking where FreeType 2.x is installed...
using libfreetype from -L/usr/lib64 -Wl,--rpath -Wl,/usr/lib64
-lfreetype -lz
checking for FT_Init_FreeType in -lfreetype... yes
using libfreetype -lfreetype from system libs.
Robert W. Burgholzer
Nonpoint Source Data Analyst
University of Maryland, College Park
Chesapeake Bay Program Office
410 Severn Avenue, Suite 305B
Annapolis, MD, 21403
Phone: (410) 267-5779
rburghol at chesapeakebay.net
http://www.chesapeakebay.net/
