draw a line with arrows indicating dire ction of tavel...
John Cole john.cole at UAI.COM
Sat Jun 10 10:51:25 EDT 2006
Thanks, works perfect now.  Really cool!  I can't say how much easier and
fun it is working with MapServer and PostGIS over the ESRI suite.
Thanks guys.
John
-----Original Message-----
From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
Sent: Friday, June 09, 2006 4:07 PM
To: John Cole
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] draw a line with arrows indicating
direction of tavel...
John,
Set the gap to a negative number in your symbol definition.
-SteveW
John Cole wrote:
> Hello, I'm trying to render a line and show the direction of travel
> (the points in the lines are in the proper order).  Attempting to use
> a true type symbol, and come to find it is working as designed :-)
http://mapserver.gis.umn.edu/docs/howto/cartosymbols/#signatures-of-type-tru
>  etype
> So, how do I go about rendering an arrow at regular intervals along a
> line and have them follow the direction of the points in the line?
> Thanks,
> John Cole This email and any files transmitted with it are
> confidential and intended solely for the use of the individual or
> entity to whom they are addressed. If you have received this email in
> error please notify the sender. This message contains confidential
> information and is intended only for the individual named. If you are
> not the named addressee you should not disseminate, distribute or
> copy this e-mail.
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
