c#-mapscript, display Image without saving on disk and zoom
Tamas Szekeres
szekerest at GMAIL.COM
Sat Jun 10 16:56:53 EDT 2006
Christian,
Beginning with 4.8.0 you can utilize imageObj.getBytes to get the generated
image as a byte array. You can use for example:
private void RefreshMap()
using(imageObj image = myMap.draw())
byte[] img = image.getBytes();
using (MemoryStream ms = new MemoryStream(img))
Image mapimage = Image.FromStream(ms);
if (this.map.Image != null)
this.map.Image.Dispose();
this.map.Image = null;
this.map.Image = mapimage;
Alternatively if you are using the CVS version you can use
imageObj.write(System.IO.Stream stream) to write
the contents of the image onto a previously generated stream object.
I hope your zoom problem could be solved accordingly.
Note: If you would like use mapObj.zoomRectange() the miny and maxy of the
given rectangle should be swapped with the previous releases. For example:
private void ZoomRectangle(rectObj imgrect)
double c = imgrect.miny;
imgrect.miny = imgrect.maxy;
imgrect.maxy = c;
map.zoomRectangle( imgrect, myMap.width, myMap.height, myMap.extent,
null);
RefreshMap();
This problem was corrected with the current CVS HEAD.
Best Regards,
Tamas
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Christian Wilmes
Sent: Thursday, June 08, 2006 6:01 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] c#-mapscript, display Image without saving on
disk and zoom
Hi All,
I've got 2 questions about c#-mapscript:
1. Is it possible to display the image coming from the mapserver without
saving it on disc before?
In the moment I only realized it with saving on disc:
imageObj image = myMap.draw();
image.save("test.jpeg", myMap);
this.map.Image = Image.FromFile("test.jpeg");
2. I'm trying to realize a zoom, but theres the same problem again....how
can I do that without saving the image. If I save the Image the zoom is
correct.
In the moment my zoom-function looks like that (it doesn't work):
public void zoomIn(Object obj, MouseEventArgs ea)
myMap.zoomPoint(2, new pointObj(ea.X, ea.Y, 0, 0),
this.map.Width, this.map.Height,
myMap.extent,
new rectObj(-90, -180, 90, 180, 0));
this.map.Refresh();
I would be very thankful for any help!
Best Regards
Christian
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.394 / Virus Database: 268.8.3/360 - Release Date: 2006.06.09.
No virus found in this outgoing message.
