Query by point
DjwStone
D.Stone at ED.AC.UK
Mon Jun 12 09:51:06 EDT 2006
Apologies if this is a repeat post -- I've been away for a bit.
A strange thing is happening when I do (CGI) query-by-point, clicking on a
point of the following layer. If I select 'Andrew' (say) as the 'stname' on
the map template, I see a map with the correct dots for 15th century church
dedications to Andrew. But if I then set the mode to 'query' or 'nquery' and
click on a dot, the 'result.html' template appears with attribute values for
records which only meet the location and date criteria (deddlo, deddhi) and
not the stname or dedicationtype criteria, e.g it might be an altar
dedication to Barbara.
I've tried removing the complicated date criteria from the DATA status, and
then the query-by-point seems to work OK. Needless to say, however, this is
not an acceptable solution!
Can anyone suggest what is going wrong? It will be a real show-stopper if I
can't circumvent this.
Cheers,
Dave
LAYER # query layer using the saintloc PostgreSQL view
CONNECTIONTYPE postgis
NAME saint_chdedlocs_C15
CONNECTION "user=erdb13 dbname=stdraft"
DATA "geom from (select dr, geom, stdname, reftostconf,
saintid, locationref, deddlo, deddhi, dedicationtype, stdesc, oid from
saintloc where ((deddlo >= 14010101) AND (deddlo <= 15001231)) OR ((deddhi
>= 14010101) AND (deddhi <= 15001231)) AND dedicationtype = 'Church
dedication') as foo using srid=27700"
STATUS OFF
DEBUG ON
TYPE POINT
FILTERITEM stdname
FILTER "stdname='%stname%'"
TOLERANCE 25
HEADER "result_hdr.html"
FOOTER "result_ftr.html"
CLASS
NAME "Church dedications - 15C"
MINSCALE 2000000
TEMPLATE "result.html"
DEBUG ON
STYLE
SYMBOL "square"
SIZE 5
COLOR 51 255 255
OUTLINECOLOR 0 0 0
END
END
etc.
END # test query layer
View this message in context: http://www.nabble.com/Query-by-point-t1774168.html#a4829017
Sent from the Mapserver - User forum at Nabble.com.
