mapserver initialization delays
Scott Melby
smelby at TURNKEY-TECHNOLOGY.COM
Mon Jun 12 12:51:18 EDT 2006
Hello -
I am pretty new to MapServer, so I apologize if I am re-hashing old
material. However, I am having a significant problem and am unable to
find a "reasonable" solution documented anywhere. I am running
mapserver 4.6, and am serving a single layer that contains about 350,000
points from a PostGIS database. The layer has a GiST index on the
geometry column. The following request
http://www.geonomy.com/cgi-bin/mapserv?map=/var/www/geonomy/geonomy.map&layer=geonomy_features&mode=map&dataFilter=geometry%20is%20not%20null
will draw all points in my table into a 256x256 RGB PNG file. The issue
I am having is that MapServer can take up to 3 minutes to draw the image
the first time it is called(after any delay of 30+ minutes with no
calls). Once that initial draw completes, subsequent hits draw in about
9 seconds. In my research I have found a page that indicates that this
is due to MapServer initialization. But the advice given there was to
send a request that causes all map features to be drawn after setting up
the server.... which has not solved my problems. The delay does not
appear to be tied to a particular client session... because hitting that
same URL from another browser draws quickly if done within a few minutes
of the initial query. However, if I wait long enough (seems to be about
20-30 minutes) the next request will once again take 2-3 minutes instead
of 9 seconds. Note: I don't believe that the issue is due to
efficiencies of drawing the same image or accessing the same data
repeatedly, because I have found that altering the dataFilter parameter
(which is passed to a FILTER on the layer in the map file) causes the
image to change, but does not significantly alter the performance
(filters with less points draw more quickly, but still take a relatively
long time for initial query if delay is long enough before it is
called). I have looked at the mapserver demo_init.html file and have
added code to my servlet that periodically performs the following get
http://www.geonomy.com/cgi-bin/mapserv?map=/var/www/geonomy/geonomy.map&layer=geonomy_features&program=/cgi-bin/mapserv&map_web_imagepath=/tmp&map_web_imageurl=/tmp
request every N minutes (intervals of 1 minute - 10 minutes)... but,
this does not change the behavior.
I have also tried performing the following get at 1 minute intervals to
try to avoid problems that could be caused by inactivity (such as the
GiST index having to be reloaded from disk, or mapserver dropping its
connection to PostGIS).. In this case the GET request is being sent
from a Java using a HttpURLConnection that is set to not use caches.
Note: I have also tried adding a BBOX to this request to make sure that
the GiST index is being used. However, this does not fix the problem
either.
http://www.geonomy.com/cgi-bin/mapserv?map=/var/www/geonomy/geonomy.map&REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&LAYERS=geonomy_features&FORMAT=PNG&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SRS=EPSG:4326&BBOX=-115,30,-108,37&WIDTH=256&HEIGHT=256&reaspect=false&dataFilter=geometry%20is%20not%20null
Any help is greatly appreciated.
Thanks in advance
Scott
