Problem with the mailinglist
Luis Treviño Huerta
ltrevino at GPOBSI.COM.MX
Mon Jun 12 14:42:59 EDT 2006
Christian:
I have the same problem if I try to sent a mail directly from the
mailinglist homepage, so I send the mails to the list from outside the
mailinglist homepage and don´t have problems.
Luis
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Monday, June 12, 2006 2:59 AM
Subject: Re: [UMN_MAPSERVER-USERS] Problem with the mailinglist
>>sorry, you are right, of course it was the 9th of June. I can't see any
>>regularity for the delay, it just seems to be chance.
> So where do I have to search the problem? It seems nobody else have the
> same problems, so could it be a problem of my mail-provider (gmx.de)?
> This message was sent on Monday the 12th of june at 09:53am german time.
> Best Regards
> Christian
> -------- Original-Nachricht --------
>> Datum: Sat, 10 Jun 2006 08:39:08 +0200
>> Von: Manfred Meier <m.meier at SPIEKERMANN.DE>
>> An: MAPSERVER-USERS at LISTS.UMN.EDU
>> Betreff: Re: [UMN_MAPSERVER-USERS] Problem with the mailinglist
> Hi,
>> in my mailbox this message showed up on Sat, 10. June 2006 at about
>> 08:35 German time.
>> Friday was the 9th of June not the 8th. Was that a typo?
>> Manfred Meier
>> Christian Wilmes schrieb:
>> > Hi all,
>> > I've got some problems with this mailinglist. If I sent a mail to the
>> list it takes hours or even days until it is in the list. If I try to
>> sent
>> a mail directly from the mailinglist homepage, after a few seconds I get
>> the following mail:
>> > Rejected posting to MAPSERVER-USERS at LISTS.UMN.EDU
>> > Your message is being returned to you unprocessed because it appears
>> to have already been distributed to the MAPSERVER-USERS list. That is,
>> a
>> message with identical text (but possibly with different mail headers)
>> has been posted to the list recently, either by you or by someone
>> else.
>> If you have reason to resend this message to the list (for instance
>> because you have been notified of a hardware failure with loss of data),
>> please alter the text of the message in some way and resend it to the
>> list. Note that altering the "Subject:" line or adding blank lines at
>> the
>> top or bottom of the message is not sufficient; you should instead add
>> a
>> sentence or two at the top explaining why you are
>> > resending the message, so that the other subscribers understand why
>> they are getting two copies of the same message.
>> > > Because of these things it happens in the last time, that I was
>> sending
>> a mail more than one time, sorry for that!
>> > > I hope someone who is responsible for the mailinglist will read this
>> mail and is probatly able to help me.
>> > This mail for example I will send at on Friday 08.06.2006 at 11:20am
>> German time....wonder how long it will take this time until the mail is
>> in
>> the list.
>> > Best Regards
>> > Christian
> Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
> Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
