JavaMapscript SIGSEGV
Rodriguez, Heraldo
hrodriguez at SISCAT.COM.AR
Mon Jun 12 15:20:43 EDT 2006
Hi guys,
I have started developing with java mapscript and I have the same
problems with the shapeObj class.
Every time I want to create a new shape I get the message
> # An unexpected error has been detected by HotSpot Virtual Machine:
> # SIGSEGV (0xb) at pc=0x00002aaaaae43d5b, pid=23120, tid=46912501734144
> # Java VM: Java HotSpot(TM) Client VM (1.4.2_11-b06 mixed mode)
> # Problematic frame:
I am using mapserver 4.8.1 with java 1.4.2_11 version under Debian 3.1.
Mapserver Compiling options
./configure --with-freetype=/usr/local/bin/freetype-config
--with-zlib=/usr/lib --with-png=/usr/local/lib --with-jpeg=/usr/lib
--with-libiconv=/usr/local/lib --with-gd=/usr/local/bin/gdlib-config
--with-pdf=/usr/local/lib --with-proj=/usr/local/lib --with-threads
--with-geos=/usr/local/bin/geos-config --with-ogr=/usr/local/bin/gdal-config
--with-gdal=/usr/local/bin/gdal-config
--with-postgis=/usr/local/pgsql/bin/pg_config --with-wfs --with-wcs
--with-wmsclient --with-curl-config=/usr/local/bin/curl-config
Steps to compile java mapscript
Run make
Make interface (swig version 1.3.29)
Make all
I looked for a solution in google and mapserver documentation without
success. Could you please give me a clue to solve this? Thanks in
advance.
Best regards.
Heraldo G. Rodriguez
hrodriguez at siscat.com.ar
TE 4326-4002 int 255
Dpto. Desarrollo
Sistemas Catastrales S.A
-----Mensaje original-----
De: Andre Sachs [mailto:asachs at CLUE.CO.ZA]
Enviado el: miércoles, 31 de mayo de 2006 5:16
Para: MAPSERVER-USERS at LISTS.UMN.EDU
Asunto: Re: [UMN_MAPSERVER-USERS] JavaMapscript SIGSEGV
On 31 May 2006, at 8:37 AM, Umberto Nicoletti wrote:
> Andre, could you report whether the patch attached to gentoo bugzilla
> works or not?
Hi Umberto,
Sorry for not replying earlier.
The patch works in a 32 intel environment, thanks !
Due to time constraints on my current project I ditched my AMD 64,
Java 1.5 64 bit environment in favour of Intel 32 bit and this has
resolved my problem.
The problems I experienced are somewhere in the application stack,
either in :
- Sun's 64 bit 1.5 jdk
- Gentoo's glibc 2.3.5-r2
- Linux kernel 2.6.16
Once my current project is over (+- 3 weeks) I will be have some
spare time to hunt down the culprit.
Regards,
Andre
Andre Sachs
IT Architect, Clue Technologies PTY (LTD)
email: andre at clue.co.za
