Using Mapserver on VPS with cPanel?
Eijnden, B. van den (Bart) b.vdeijnden at AGI.RWS.MINVENW.NL
Tue Jun 13 02:22:06 EDT 2006
PHP/Mapscript can actually run as an Apache DSO (the Wiki page is quite
outdated), there might be some problems though depending on your use case.
Best regards,
Bart
-----Oorspronkelijk bericht-----
Van: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens
Volkan Ulukut
Verzonden: dinsdag 13 juni 2006 8:27
Aan: MAPSERVER-USERS at LISTS.UMN.EDU
Onderwerp: Re: [UMN_MAPSERVER-USERS] Using Mapserver on VPS with cPanel?
We have a dedicated server using rhe 4 and cPanel 10.8.2. I've installed
MapServer last week and it had no problems with cPanel at all. The problem
you might encounter is that MapScript needs php execute as cgi. So you need
a seperate php install if you have php installed as an Apache DSO. Check
this link out:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptCGI
<http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptCGI>
-----Original Message-----
From: tesciltu at host.tescilturk.com [mailto:tesciltu at host.tescilturk.com] On
Behalf Of Michael Slater
Sent: Tuesday, June 13, 2006 8:16 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Using Mapserver on VPS with cPanel?
I have a site hosted at ServInt on a virtual private server (VPS) running
Red Hat 9, Virtuozzo, and Cpanel. The network ops folks have dissuaded me
from installing Mapserver, saying in part:
"The requirements for this application would most likely cause instability
on a VPS. Additionally, there are no pre-made binaries for RedHat 9.0. You
would probably need a Mapserver expert to install this software for you on
your VPS, and it would most likely break functionality with other things
(like cPanel). It is not something that looks like it would play nicely with
the software that cPanel installs. It looks like it would require a self
contained PHP daemon."
Are they being too cautious, or should I give up on installing this? My goal
is to be able to dynamically render the NOAA ENC charts. Is there a simpler
alternative for doing so?
Anyone out there with cPanel experience who would be interested in a project
to install this?
Thanks,
Michael Slater
www.BoatingSF.com
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060613/3c8ad049/attachment.html
