Problem with the mailinglist
Christian Wilmes C.Wilmes at GMX.DE
Tue Jun 13 02:49:40 EDT 2006
Hi Perry,
thank you for your help. In the future I will do it like you told me.
Best Regards
Christian
-------- Original-Nachricht --------
Datum: Mon, 12 Jun 2006 14:05:57 -0500
Von: "Pericles S. Nacionales" <naci0002 at UMN.EDU>
An: MAPSERVER-USERS at LISTS.UMN.EDU
Betreff: Re: [UMN_MAPSERVER-USERS] Problem with the mailinglist
> Christian,
> If you or anyone run into this problem again please send mailadm at umn.edu
> an e-mail outlining the problem (it is their request).  Also, please CC
> me on that e-mail so I can keep track of the issues.  No one is exactly
> sure how this issue is propagated but it's happened to a few (you're the
> fourth person I know who has gotten this message).  Maybe it has to do
> with the UMN's mail server...
> Thanks,
> Perry
> Christian Wilmes wrote:
> >>> That couldn't be the problem, I haven't choose that option. But the
> last time it seems to work. I get my own message at 9:59.
> > So hoping I've got luck again and this message will be in the list in a
> few minutes too.
> > Mo 11:02 am German Time.
> >>  Datum: Mon, 12 Jun 2006 10:08:43 +0200
> >>  Von: Manfred Meier <m.meier at SPIEKERMANN.DE>
> >>  &#xA> Hi,
> >> I received this message on Monday 12, 10:00 German time. Not bad!
> >> A long time ago, when I did subscribe to the list there was an option
> to
> >> get all mails bundled once a day. Can this be the problem in your case?
> >> Greetings
> >> Manfred Meier
> >> Christian Wilmes schrieb:
> >>>> sorry, you are right, of course it was the 9th of June. I can't see
> any
> >> regularity for the delay, it just seems to be chance.
> >>>> So where do I have to search the problem? It seems nobody else have
> >> the
> >> same problems, so could it be a problem of my mail-provider (gmx.de)?
> >>> This message was sent on Monday the 12th of june at 09:53am german
> time.
> >>> Best Regards
> >>> Christian
> >>>> Datum: Sat, 10 Jun 2006 08:39:08 +0200
> >>>> &#xA> Hi,
> >>>> in my mailbox this message showed up on Sat, 10. June 2006 at about
> >>>> 08:35 German time.
> >>>> Friday was the 9th of June not the 8th. Was that a typo?
> >>>> Manfred Meier
> >>>>> Hi all,
> >>>>> I've got some problems with this mailinglist. If I sent a mail to
> the
> >>>> list it takes hours or even days until it is in the list. If I try to
> >> sent
> >>>> a mail directly from the mailinglist homepage, after a few seconds I
> get
> >>>> the following mail:
> >>>>> Rejected posting to MAPSERVER-USERS at LISTS.UMN.EDU
> >>>>> Your message  is being returned to  you unprocessed because it
> appears
> >>>> to have already been distributed  to the MAPSERVER-USERS list. That
> is,
> >> a
> >>>> message with identical text  (but possibly with different  mail
> headers)
> >>>> has been  posted to the list  recently, either by  you or  by someone
> >>>> else.
> >>>> If you have  reason to resend this message to the list (for instance
> >>>> because you have been notified of a hardware failure with loss of
> data),
> >>>> please alter the text of the message in some way and resend  it to
> the
> >>>> list. Note that altering  the "Subject:" line or adding blank lines
> at
> >>>> the
> >>>> top or bottom of the message  is not sufficient; you should  instead
> add
> >>>> a
> >>>> sentence or  two  at  the top  explaining  why you  are
> >>>>> resending the  message, so that the  other subscribers understand
> why
> >>>> they are getting two copies of the same message.
> >>>>>> Because of these things it happens in the last time, that I was
> >>>> sending
> >>>> a mail more than one time, sorry for that!
> >>>>>> I hope someone who is responsible for the mailinglist will read
> this
> >>>> mail and is probatly able to help me.
> >>>>> This mail for example I will send at on Friday 08.06.2006 at 11:20am
> >>>> German time....wonder how long it will take this time until the mail
> is
> >> in
> >>>> the list.
> >>>>> Best Regards
> >>>>> Christian
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
