How to Lat, long info in the browser?
muthu veerappan
muthu_manaparai at YAHOO.COM
Tue Jun 13 03:39:55 EDT 2006
Hi Raffle Peter,
This is a Map SERVER list - I hope you are asking a
map client question, but anyway let me try to answer.
I have used many clients and would suggest you to look
in to mapbuilder's code (complex - generalized code).
It might confuse us, but have a look. Worth it.
Lat, Lan display is not a easy job, if you have
different projections (SRS - UTM, EPSG, SCENE, PIXEL).
We are displaying in a flat surface (monitor),
depending upon the projection you need to display the
lat, lan.
First consider it as a flat surface and then capture
the mouse events from the browser.
look at http://dunnbypaul.net/js_mouse
if you need to display simple lat, lan for a map image
,then do the pixel x-y:lat-lan ratio
disclaimer - My understanding may be wrong too. ! If
so, Hope someone here would correct !
Regards,
Muthu Veerappan PR
Date: Mon, 12 Jun 2006 10:24:42 +0100
Subject: How to Lat, long info in the browser?
Hi
Can anyone plz. guide me how to show the latitude,
longitude information in the status bar of the window
or in the page using php/mapscript when i move the
mouse over the map. In detail explanation or from
where to
start the coding for that will really help me. I am
using the GMAP map engine.
Thanks in advance
Raffle
PR.Muthu Veerappan (முத்து வீரப்பன்)
Mobile +971 50 4206576 (Dubai)
e-Mail - muthu at periyakaruppan.com
Check http://www.periyakaruppan.com
Join http://www.buddhibase.org
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
