css in template file
Micha Silver
micha at ARAVA.CO.IL
Tue Jun 13 08:27:15 EDT 2006
Perfect! That was it.
Warm thanks,
Micha
Janeks Kamerovskis wrote:
>It looks like you should play with those "/" and "." before file name in
>stylesheet definition.
>F.ex. if template and *.css are in the root directory, then line:
><link rel="stylesheet" type="text/css" href="/filename.css">
>works.
>Of couse there could be different combinations:
>/../filename.css
>/dirname/filename.css
>etc.
>Janeks
>>-----Original Message-----
>>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
>>Behalf Of Micha Silver
>>Sent: Tuesday, June 13, 2006 1:24 PM
>>To: MAPSERVER-USERS at LISTS.UMN.EDU
>>Subject: [UMN_MAPSERVER-USERS] css in template file
>>Can I use a css style sheet in a template file?
>>I have a css file set up, and if I open the template (html) file
>>directly, the styles are correctly applied. However when I run a map
>>file from the mapserv cgi (with the template defined in the map file) I
>>see my map, and all the html tags but the styles are NOT applied.
>>What have I done wrong?
>>Thanks,
>>Micha
