MyGis connection question
Fawcett, David
David.Fawcett at STATE.MN.US
Tue Jun 13 08:57:45 EDT 2006
John,
Take a look at this: http://mapserver.gis.umn.edu/docs/howto/ogrmysql
You would need to change your data structure so that you store your x
and y values in separate columns.
Note that this method doesn't use MyGIS, it uses a direct connection
driver in OGR, so your MapServer binary would need to be compiled with
OGR support (as most are).
David.
-----Original Message-----
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of John Prof
Sent: Tuesday, June 13, 2006 4:03 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] MyGis connection question
Hello,
I'm trying to connect mapserver's map with a mysql datatable
like this:
id int
name varchar(20)
description varchar(100)
location point
I'd like to create a shape with the points and the labels of the
name. Is it possible? I've tried many ways but I have errors.
I'd like to do something like this example:
LAYER
CONNECTIONTYPE mygis
NAME "City"
CONNECTION "host:user:passwd:database:bin"
DATA "location from city"
TYPE POINT
STATUS ON
END
It fails. I've tried with some mysql functions like
AsBinary(point), but it doesn't work.
I must use sh2mysql structure to store data in my database? Is
not possible make my simply case?
Thanks and sorry for my english :p
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060613/b1023b05/attachment.html
