compile MapServer to support Oracle Spa tial
Zhonghai Wang
zhonghaiw at GMAIL.COM
Tue Jun 13 09:01:47 EDT 2006
Hi Bart,
I noticed that, for Windows on the Instant Client is needed, the Instant
Client SDK is only needed for Linux, is that right?
I read this in the Oracle home page, but I am not familiar with Oracle and
not sure about this.
thanks for your feedback.
zhonghai
On 6/13/06, Eijnden, B. van den (Bart) <b.vdeijnden at agi.rws.minvenw.nl>
wrote:
> You need to install the Oracle client libraries (which include OCI), not
> Oracle server.
> The easiest you can use is the Oracle instant client which is less than
> 100 Mb and can just be deployed by unpacking a ZIP. You also need the
> Instant Client SDK then for the header files. Check the Oracle site.
> Best regards,
> Bart
> -----Oorspronkelijk bericht-----
> *Van:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]*Namens
> *Zhonghai Wang
> *Verzonden:* dinsdag 13 juni 2006 11:46
> *Aan:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Onderwerp:* [UMN_MAPSERVER-USERS] compile MapServer to support Oracle
> Spatial
> Hi there,
> I am now trying to compile MapServer to support Oracle Spatial, I find the
> info in the nmake.opt:
> # Direct connectivity to Oracle Spatial.
> # Point this to where your ORACLE_HOME directory lives.
> ORACLE_DIR = d:\oracle\ora92
> ORACLE=-DUSE_ORACLESPATIAL
> does this mean that I must install Oracle on my computer, before I compile
> the MapServer? If not necessary, how can I set the
> ORACLE_DIR = value? set it as a virtual directory?
> thanks
> zhonghai
> Disclaimer
> ************************************************************************ Aan
> dit bericht kunnen geen rechten worden ontleend. Dit bericht is uitsluitend
> bestemd voor de geadresseerde. Als u dit bericht per abuis hebt ontvangen,
> wordt u verzocht het te vernietigen en de afzender te informeren. Wij
> adviseren u om bij twijfel over de juistheid of de volledigheid van de mail
> contact met afzender op te nemen. This message shall not constitute any
> rights or obligations. This message is intended solely for the addressee. If
> you have received this message in error, please delete it and notify the
> sender immediately. When in doubt whether this message is correct or
> complete, please contact the sender.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060613/bfca0897/attachment.html
