Anti Alias Problem
Thomas Hammerlund
tom at MAPLINK.JP
Wed Jun 14 03:23:52 EDT 2006
Thank you for your reply Steve.
I'm running mapserver 4.8.3 and outputting jpegs via the gdal/jpeg driver.
I'm using the gdal driver because the gd/jpeg driver output progressive
encoded jpegs(which i couldn't use).
Example layer:
LAYER
NAME l_koku_u
STATUS ON
TILEINDEX "ixs/shb/50000/l_koku_u_ix"
TILEITEM "location"
TYPE LINE
CLASSITEM Code
CLASS
MAXSCALE 337000
MINSCALE 85001
Name style1
EXPRESSION 'l_bbbcd'
STYLE
COLOR 240 184 53
WIDTH 1
#ANTIALIAS TRUE
END
END
END
I'm creating my image using perl mapscript. my mistake, the problem is not
with the fonts but with the lines. when I turn style antialiasing on for my
line layers perl throws an internal server error with no error message from
mapserver (or perl).
The outputformat in my mapfile looks like this:
OUTPUTFORMAT
NAME jpeg
DRIVER "GDAL/JPEG"
MIMETYPE "image/jpeg"
IMAGEMODE RGB
FORMATOPTION "QUALITY=100"
EXTENSION "jpg"
END
Which antialias patch are you referring to?
Thank you again,
Tom
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>; <tom at MAPLINK.JP>
Sent: Wednesday, June 14, 2006 2:56 PM
Subject: Re: [UMN_MAPSERVER-USERS] Anti Alias Problem
> Hmmm... I'm suprised turning off style antialiasing would impact font
> antialiasing.
> They are totally unrelated.
> I guess we need a bit more information. What version of MapServer? Has the
> GD
> anti-aliasing patch been applied? What output image format?
> Steve
>>>> Thomas Hammerlund <tom at MAPLINK.JP> 06/13/06 1:03 AM >>>
> Hi Everyone,
> I've been looking for a solution to this, but haven't been successful so
> far
> so I'm hoping someone can help.
> I'm using Fedora 5, and everything I need is working great. The problem
> is
> that when I try the same data set on Fedora 4 or Red Hat Advanced Server,
> anti alias doesn't work. The problem can be resolved by commenting out
> the
> antialias line, but then it makes my font and lines look too choppy. Has
> anyone seen this? Does anyone know if this is a Linux or a Mapserver
> problem?
> Thank you for your help,
> Tom
