Mapscript ,Mono, Apache and Linux : a great story
Xavier Mauclaire
xavier.mauclaire at GEOTER.FR
Thu Jun 15 04:54:56 EDT 2006
Hi Tamas
You will find next information which may help.
Thanks in advance for your help
The problem is that the server scratches randomly occurs. However, i saw in the logs (if the variable MALLOC_CHECK_ equals 0) the segmentation fault appears a lot of time in GetFeature function. I saw in the mailing List emails concerning this problem with Java.
You will find next :
1) piece of code c#
2) mapfile used
3) apache2 error_log file
system informations :
apache 2.2 (ia upgrade apache yesterday 2.0.54 to 2.2)
Mono 1.1.13
mod_mono 1.1.14
mapserver 4.8.3 with mapscript csharp
postgresql 8.1.3
Postgis 1.1.1
gdal 1.3.1
geos 2.2.1
gd-2.0.33
libiconv 1.9.
Compilation options of Mapserver
./configure --with-gdal=/usr/local/bin/gdal-config --with-ogr=/usr/local/bin/gdal-config --with-postgis=/usr/local/pgsql/bin/pg_config --with-xpm=/usr/local/lib --with-ming --with-png --with-jpeg --with-zlib --with-libiconv--without-tiff --with-threads --with-geos=/usr/local/bin/geos-config --with-gif --with-proj --with-gd=/usr/local -without-wms
I'm really need any help. I don't know what to do.
I'm sure that architecture choices i've done are good So it has to be working :-)
regards
1) Piece of Code where
private shapeObj localiser_parcelle(Double dX, Double dY, out String zParcelleIdent){
shapeObj pShape = null;
zParcelleIdent = "";
int liRes ;
try {
// recupération de la layer des parcelle
// celle dont le nom est CONST_LAYERNAME_PARCELLE
layerObj pLayerParcelle = pMapQuery.getLayerByName(cConstantes.CONST_LAYERNAME_PARCELLE);
if(pLayerParcelle != null){
// creation du poitn de localisation
pointObj pPoint = new pointObj(dX, dY,0.0,0.0 );
// on recherche la parcelle au point cliqué
pLayerParcelle.queryByPoint(pMapQuery,pPoint,mapscript.MS_SINGLE,0);
resultCacheObj pRes = pLayerParcelle.getResults();
try{
resultCacheMemberObj pResMember = null;
if(pRes.numresults > 0) {
//on zoom sur la selection courante
pMapQuery.setExtent(pRes.bounds.minx,pRes.bounds.miny,pRes.bounds.maxx,pRes.bounds.maxy);
pLayerParcelle.open();
try{
// récupération de la première parcelle
pResMember = pRes.getResult(0);
pShape = pLayerParcelle.getFeature(pResMember.shapeindex, pResMember.tileindex);
if(pShape != null) {
// récupération de l'identifiant de la parcellle
Int32 liRang = -1;
// recherche rang champs
liRang = cRegInfos.SetLayerFieldRang(pLayerParcelle, cRegInfo.CONST_IDPARCELLE);
zParcelleIdent = pShape.getValue(liRang);
} //end if
}finally{
pLayerParcelle.close();
} //e nd finally
} //e nd if
} finally {
pRes.Dispose();
pRes = null;
} //e nd finally
} else
throw new Exception("Couche des parcelles introuvable");
} finally{
} //end finally
return pShape;
} // end function
2) Mapfile
MAP
NAME MAPFILE
STATUS ON
SHAPEPATH "/home/raster971/"
# Map image size. Change size as desired
SIZE 750 750
IMAGETYPE png
# Extent based on full extent of QGIS view
EXTENT 635000 1768500 645000 1778700
SYMBOLSET "symbols/symbols.sym"
IMAGECOLOR 255 255 255
FONTSET "fonts/fonts.list"
# Start of web interface definition. Only the TEMPLATE parameter
# must be specified to display a map. See Mapserver documentation
WEB
IMAGEPATH ""
IMAGEURL "/tmp/"
END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
EXTENSION "png"
IMAGEMODE RGB
TRANSPARENT OFF
END
SCALEBAR
IMAGECOLOR -1 -1 -1
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 0 0 0
LABEL
COLOR 0 0 0
END
SIZE 150 5
COLOR 255 255 255
UNITS METERS
INTERVALS 4
TRANSPARENT on
STATUS EMBED
STYLE 0
POSITION LR
END
LAYER
NAME limites_communales
TYPE POLYGON
STATUS DEFAULT
CONNECTION "user=postgres password=trucmuche dbname=pprsaintclaude host=localhost port=5432"
CONNECTIONTYPE postgis
DATA "wkb_geometry from limites_communales"
CLASS
NAME "commune"
END
END
LAYER
NAME zonage_reglementaire
TYPE POLYGON
STATUS DEFAULT
TEMPLATE "rien.htm"
DATA "wkb_geometry from zonage_reglementaire"
CLASSITEM "code_reg"
CLASS
NAME "0"
EXPRESSION "0"
COLOR 255 255 255
OUTLINECOLOR -1 -1 -1
END
CLASS
NAME "1"
EXPRESSION "1"
COLOR 160 224 255
END
CLASS
NAME "2"
EXPRESSION "2"
COLOR 64 192 255
END
CLASS
NAME "3"
EXPRESSION "3"
COLOR 0 0 255
END
CLASS
NAME "4"
EXPRESSION "4"
COLOR 255 128 128
END
CLASS
NAME "5"
EXPRESSION "5"
STYLE
SYMBOL "hatch45"
COLOR 255 0 0
SIZE 6
WIDTH 1
END
END
CLASS
NAME "6"
EXPRESSION "6"
COLOR 255 0 0
END
CLASS
NAME "7"
EXPRESSION "7"
COLOR 96 160 0
END
CLASS
NAME "8"
EXPRESSION "8"
COLOR 160 224 255
OUTLINECOLOR 0 255 255
END
END
LAYER
NAME parcelles
TYPE POLYGON
STATUS DEFAULT
TEMPLATE "rien.htm"
DATA "wkb_geometry from parcelles"
CLASS
NAME "parcelle"
COLOR -1 -1 -1
OUTLINECOLOR 0 0 0
END
END
# alea
LAYER
NAME alea_mvt
METADATA
"NOM_ALEA" "Al� mouvement de terrain"
END
TEMPLATE "rien.htm"
TYPE POLYGON
STATUS DEFAULT
DATA "wkb_geometry from alea_mouvement_terrain"
END
LAYER
NAME alea_houle
METADATA
"NOM_ALEA" "Al� houle"
END
TEMPLATE "rien.htm"
TYPE POLYGON
STATUS OFF
DATA "wkb_geometry from alea_houle"
END
LAYER
NAME alea_liquefaction
METADATA
"NOM_ALEA" "Al� liqu�ation"
END
TEMPLATE "rien.htm"
TYPE POLYGON
STATUS OFF
DATA "wkb_geometry from alea_liquefaction"
END
LAYER
NAME alea_faille
METADATA
"NOM_ALEA" "Al� faille active"
END
TEMPLATE "rien.htm"
TYPE POLYGON
STATUS OFF
DATA "wkb_geometry from alea_faille"
END
LAYER
NAME alea_sismique
METADATA
"NOM_ALEA" "Al� sismique"
END
TEMPLATE "rien.htm"
TYPE POLYGON
STATUS OFF
DATA "wkb_geometry from alea_sismique"
END
LAYER
NAME alea_inondation
METADATA
"NOM_ALEA" "Al� inondation"
END
TEMPLATE "rien.htm"
TYPE POLYGON
STATUS DEFAULT
DATA "wkb_geometry from alea_inondation"
END
LAYER
NAME "North Arrow"
STATUS OFF ##DEFAULT
TRANSFORM OFF
TRANSPARENCY 100
POSTLABELCACHE TRUE
TYPE POINT
FEATURE
POINTS 580 720 END
END
CLASS
SYMBOL 'northarrow1'
SIZE 50
END
END
END # Map File
3) Logs in the apache error_log file
The following logs show error information of two scratches (After each segmentation fault i have to restart apache). You can notice the the error does not appears et the same location (Garbage collector of mono ??)
[Fri Jun 16 10:41:41 2006] [notice] Apache/2.2.0 (Unix) mod_mono/1.1.14 configured -- resuming normal operations
Another mod-mono-server with the same arguments is already running.
Got a SIGSEGV while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Stacktrace:
in (wrapper managed-to-native) mapscriptPINVOKE:delete_layerObj (System.Runtime.InteropServices.HandleRef) <0x4>
in (wrapper managed-to-native) mapscriptPINVOKE:delete_layerObj (System.Runtime.InteropServices.HandleRef) <0xfe880ea1>
in layerObj:Dispose () <0x41>
in layerObj:Finalize () <0xe>
in (wrapper runtime-invoke) System.Object:runtime_invoke_void (object,intptr,intptr,intptr) <0xc68dba2f>
Native stacktrace:
/usr/lib/pkgconfig/../../bin/mono(mono_handle_native_sigsegv+0xbb) [0x814ee2b]
/usr/lib/pkgconfig/../../bin/mono [0x813b2cf]
[0xffffe440]
/usr/local/lib/libmapscript.so(msFree+0x21) [0x41a4c951]
/usr/local/lib/libmapscript.so(freeLayer+0x35) [0x41a50655]
/usr/local/lib/libmapscript.so(CSharp_delete_layerObj+0x7f) [0x41a28fef]
[0x42fdeb6c]
[0x4185f9aa]
[0x4185f947]
[0x4185f779]
/usr/lib/pkgconfig/../../bin/mono [0x813b180]
/usr/lib/pkgconfig/../../bin/mono(mono_runtime_invoke+0x27) [0x80d63f7]
/usr/lib/pkgconfig/../../bin/mono [0x80d2dc5]
/usr/lib/pkgconfig/../../bin/mono [0x8114cc7]
/usr/lib/pkgconfig/../../bin/mono [0x80d3b7c]
/usr/lib/pkgconfig/../../bin/mono [0x8099fb2]
/usr/lib/pkgconfig/../../bin/mono [0x80f5067]
/usr/lib/pkgconfig/../../bin/mono [0x8113175]
/lib/tls/libpthread.so.0 [0x400e5297]
/lib/tls/libc.so.6(__clone+0x5e) [0x401e037e]
[Fri Jun 16 10:43:55 2006] [notice] caught SIGTERM, shutting down
[Fri Jun 16 10:43:56 2006] [notice] Apache/2.2.0 (Unix) mod_mono/1.1.14 configured -- resuming normal operations
Stacktrace:
in (wrapper managed-to-native) mapscriptPINVOKE:layerObj_getFeature (System.Runtime.InteropServices.HandleRef,int,int) <0x4>
in (wrapper managed-to-native) mapscriptPINVOKE:layerObj_getFeature (System.Runtime.InteropServices.HandleRef,int,int) <0xffffff87>
in layerObj:getFeature (int,int) <0x27>
in siteflash.GetParcelleReglement:localiser_parcelle (double,double,string&) <0x1df>
in siteflash.GetParcelleReglement:ProcessRequest (System.Web.HttpContext) <0x56c>
in <Pipeline>__1:MoveNext () <0x10a0>
in System.Web.HttpApplication:Tick () <0x1f>
in System.Web.HttpApplication:Start (object) <0x37>
in System.Web.HttpApplication:System.Web.IHttpAsyncHandler.BeginProcessRequest (System.Web.HttpContext,System.AsyncCallback,object) <0x68>
in System.Web.HttpRuntime:RealProcessRequest (object) <0x1ab>
in System.Web.HttpRuntime:ProcessRequest (System.Web.HttpWorkerRequest) <0x2c>
in Mono.WebServer.MonoWorkerRequest:ProcessRequest () <0xa>
in Mono.WebServer.BaseApplicationHost:ProcessRequest (Mono.WebServer.MonoWorkerRequest) <0x43>
in Mono.WebServer.ModMonoApplicationHost:ProcessRequest (int,string,string,string,string,string,int,string,int,string,string[],string[]) <0xdc>
in (wrapper remoting-invoke-with-check) Mono.WebServer.ModMonoApplicationHost:ProcessRequest (int,string,string,string,string,string,int,string,int,string,string[],string[]) <0xffffff0a>
in (wrapper xdomain-dispatch) Mono.WebServer.ModMonoApplicationHost:ProcessRequest (object,byte[]&,byte[]&,int,string,string,string,string,string,int,string,int,string,string[],string[]) <0xfffee09e>
in (wrapper xdomain-invoke) Mono.WebServer.ModMonoApplicationHost:ProcessRequest (int,string,string,string,string,string,int,string,int,string,string[],string[]) <0xffffff6a>
in (wrapper remoting-invoke-with-check) Mono.WebServer.ModMonoApplicationHost:ProcessRequest (int,string,string,string,string,string,int,string,int,string,string[],string[]) <0xffba766c>
in Mono.WebServer.ModMonoWorker:InnerRun (object) <0x404>
in Mono.WebServer.ModMonoWorker:Run (object) <0x17>
in (wrapper delegate-invoke) System.MulticastDelegate:invoke_void_object (object) <0xffffff95>
in (wrapper runtime-invoke) System.Object:runtime_invoke_void_object (object,intptr,intptr,intptr) <0xc7371b5f>
Native stacktrace:
[0xffffe440]
/lib/tls/libc.so.6(malloc+0x86) [0x40187ea6]
/usr/local/pgsql/lib/libpq.so.4(pqResultAlloc+0xd5) [0x42025f25]
/usr/local/pgsql/lib/libpq.so.4(pqParseInput3+0x2b7) [0x4202e677]
/usr/local/pgsql/lib/libpq.so.4 [0x42026b04]
/usr/local/pgsql/lib/libpq.so.4(PQgetResult+0x9d) [0x4202810d]
/usr/local/pgsql/lib/libpq.so.4 [0x420282be]
/usr/local/lib/libmapscript.so(msPOSTGISLayerRetrievePGVersion+0x43) [0x41ab70e3]
/usr/local/lib/libmapscript.so(msPOSTGISLayerRetrievePK+0x31) [0x41ab7331]
/usr/local/lib/libmapscript.so [0x41ab7aa4]
/usr/local/lib/libmapscript.so(msPOSTGISLayerGetShape+0x7d) [0x41ab7e5d]
/usr/local/lib/libmapscript.so(msPOSTGISLayerGetShapeVT+0x23) [0x41ab85b3]
/usr/local/lib/libmapscript.so(msLayerGetShape+0x2e) [0x41a6db3e]
/usr/local/lib/libmapscript.so(CSharp_layerObj_getFeature+0x46) [0x41a29636]
[0x41861db2]
[0x41861cd0]
[0x41860ea8]
[0x4186048d]
[0x416f6421]
[0x416f52a8]
[0x416f1668]
[0x416f1549]
[0x41251854]
[0x41251385]
[0x41251343]
[0x41250544]
[0x41235535]
[0x41234c9c]
[0x41234a7b]
[0x41222807]
[0x41222643]
[0x40dc9bdd]
[0x40dc9730]
[0x40dc96f4]
[0x40dc964e]
/usr/lib/pkgconfig/../../bin/mono(mono_runtime_invoke_array+0x270) [0x80d78c0]
/usr/lib/pkgconfig/../../bin/mono(mono_message_invoke+0xc5) [0x80d93d5]
/usr/lib/pkgconfig/../../bin/mono [0x80a509f]
/usr/lib/pkgconfig/../../bin/mono [0x80a58c9]
Xavier Mauclaire
_____
De : Tamas Szekeres [mailto:szekerest at gmail.com]
Envoyé : mercredi 14 juin 2006 23:01
À : 'Xavier Mauclaire'; MAPSERVER-USERS at LISTS.UMN.EDU
Objet : RE: [UMN_MAPSERVER-USERS] Mapscript ,Mono, Apache and Linux : a great story
It would be helpful if you could you file a bug describing the steps to reproduce this problem (including code sample and map file if necessary).
I guess you have called a getFeature on a postgis layer which is generally not uncommon and have been tested many times.
However i am not sure about the application environment and the threading issues in this case.
Thanks,
Tamas Szekeres
_____
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Xavier Mauclaire
Sent: Tuesday, June 13, 2006 9:44 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Mapscript ,Mono, Apache and Linux : a great story
HI
I'm developping a web site using Mono (1.1.13) Apache (2.0.54) MApscript (4.8.3). I'm using Vs2003 to develop and linux as deployement platform.
All works well with windows but on linux i get the folowing error in th error_log apache file and the web server shutdowns.
Any help well be appreciated. I don't know what to do
regards
Stacktrace:
in siteflash.GetParcelleReglement:localiser_parcelle (double,double,string&) <0x1ca>
in (wrapper xdomain-dispatch) Mono.WebServer.ModMonoApplicationHost:ProcessRequest (object,byte[]&,byte[]&,int,string,string,string,string,string,int,string,int,string,string[],string[]) <0xffeecda6>
in (wrapper remoting-invoke-with-check) Mono.WebServer.ModMonoApplicationHost:ProcessRequest (int,string,string,string,string,string,int,string,int,string,string[],string[]) <0xffca7c74>
in (wrapper runtime-invoke) System.Object:runtime_invoke_void_object (object,intptr,intptr,intptr) <0xc74b289f>
Native stacktrace:
[0xffffe440]
/usr/local/lib/libmapscript.so(strstrIgnoreCase+0x47) [0x417f8fd7]
/usr/local/lib/libmapscript.so [0x417f90e4]
/usr/local/lib/libmapscript.so(msPOSTGISLayerGetShape+0x7d) [0x417f973d]
/usr/local/lib/libmapscript.so(msPOSTGISLayerGetShapeVT+0x23) [0x417f9e93]
/usr/local/lib/libmapscript.so(msLayerGetShape+0x2e) [0x417a8d6e]
/usr/local/lib/libmapscript.so(CSharp_layerObj_getFeature+0x46) [0x41764766]
[0x41721a9a]
[0x417219b8]
[0x41720b93]
[0x4172023d]
[0x415b64f9]
[0x415b5380]
[0x415b1768]
[0x415b1649]
[0x411111f4]
[0x41110d25]
[0x41110ce3]
[0x4111029c]
[0x410f54e5]
[0x410f4c4c]
[0x410f4a2b]
[0x40fe14bf]
[0x40fe12fb]
[0x40c88e9d]
[0x40c889f0]
[0x40c889b4]
[0x40c8890e]
[Tue Jun 13 17:45:12 2006] [notice] caught SIGTERM, shutting down
[Tue Jun 13 17:45:21 2006] [warn] module mono_module is already loaded, skipping
[Tue Jun 13 17:45:22 2006] [notice] Apache/2.0.54 (Linux/SUSE) configured -- resuming normal operations
[Tue Jun 13 17:53:44 2006] [notice] caught SIGTERM, shutting down
Xavier Mauclaire
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.394 / Virus Database: 268.8.4/363 - Release Date: 2006.06.13.
No virus found in this outgoing message.
Version: 7.1.394 / Virus Database: 268.8.4/364 - Release Date: 2006.06.14.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060615/ac6943b6/attachment.html
