MapServer returns cached images as new
antti siukola siukola.antti at GMAIL.COM
Thu Jun 15 06:03:58 EDT 2006
Did you get that patch working? The target milestone seems to be for
4.8 so we can expect it to be implemented in 4.9 serie at the latest?
Maybe ;)
On 6/15/06, Eijnden, B. van den (Bart) <b.vdeijnden at agi.rws.minvenw.nl> wrote:
> It's still a known issue unfortunately, check:
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1322
> Best regards,
> Bart
> -----Oorspronkelijk bericht-----
> Van: antti siukola [mailto:siukola.antti at gmail.com]
> Verzonden: donderdag 15 juni 2006 9:35
> Aan: Eijnden, B. van den (Bart)
> CC: MAPSERVER-USERS at lists.umn.edu
> Onderwerp: Re: [UMN_MAPSERVER-USERS] MapServer returns cached images as
> new
> Yes I am
> AnttiS
> wrote:
> > Are you using PHP/Mapscript? As an Apache module?
> > Best regards,
> > Bart
> > Van: UMN MapServer Users List
> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens antti
> siukola
> > Verzonden: donderdag 15 juni 2006 8:44
> > Aan: MAPSERVER-USERS at LISTS.UMN.EDU
> > Onderwerp: [UMN_MAPSERVER-USERS] MapServer returns cached images as new
> > Hi!
> > I've have a problem with mapserver returning images from cache when
> > navigating on the map. Totally random behavior. Is there some
> > configuration for this or is this a bug?
> > AnttiS
> >  Disclaimer
> > Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
> > uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
> hebt
> > ontvangen, wordt u verzocht het te vernietigen en de afzender te
> informeren.
> > Wij adviseren u om bij twijfel over de juistheid of de volledigheid van de
> > mail contact met afzender op te nemen. This message shall not constitute
> any
> > rights or obligations. This message is intended solely for the addressee.
> If
> > you have received this message in error, please delete it and notify the
> > sender immediately. When in doubt whether this message is correct or
> > complete, please contact the sender.
>  Disclaimer
> uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis hebt
> ontvangen, wordt u verzocht het te vernietigen en de afzender te informeren.
> mail contact met afzender op te nemen. This message shall not constitute any
> rights or obligations. This message is intended solely for the addressee. If
