Character set encoding problem
Erik Baluba
erik1969 at MAILHAVEN.COM
Thu Jun 15 07:04:58 EDT 2006
Hi Øyvind,
> I have data in an Oracle 10gR2 database in ISO-8859-1 encoded columns
> (WE8ISO8859P1) and the names of my geometries appear correctly in a
> sqlplus search. But on the test mapserver PNG all characters beyond
> decimal 127 (such as æøå) come out as '?'.
What is the NLS_LANG setting on the oracle client computer running your
webserver? If it is a Norwegian or English Windows the codepage is WIN1252
and your NLS_LANG would be something like Norwegian_Norway.WE8MSWIN1252. If
so I see nothing wrong with your setup because character encodings for 'æøå'
are the same in both ISO-8859-1 and WIN1252. Still, you can try to set the
ENCODING to CP1252 in your mapping file to see if it helps.
erik
> I have defined the encoding for the layer to 'ISO-8859-1'. That gives
> me the labels with '?' for the problem characters. If I write
> something wrong for the encoding, such as 'ISO-8859-', I get no labels
> at all, which is right according to the documentation. But if I enter
> a totally different encoding, such as 'EUC-JP', I get the same
> situation as with 'ISO-8859-1': Labels with '?' for the problem
> characters.
> Here is the layer from my mapfile:
> LAYER
> NAME N250ADM
> CONNECTIONTYPE oraclespatial
> CONNECTION "username/pw at service"
> DATA "GEOM FROM (select geom, navn from USD_KART_KARTV.KVN250_ADM_F)
> USING SRID 82344"
> STATUS on
> TYPE polygon
> MINSCALE 50001
> LABELCACHE on
> LABELITEM NAVN
> CLASS
> NAME "N 250 adm"
> STYLE
> COLOR 200 200 200
> OUTLINECOLOR 0 0 0
> END
> LABEL
> ENCODING ISO-8859-1
> COLOR 0 0 0
> SIZE 10
> TYPE truetype
> FONT luximr
> END
> END
> END
> I would be most grateful for any suggestion!
> Kind regards,
> Øyvind Eide
