oracle spatial
Lasse Korhonen
lasse.korhonen at KOKKOLA.FI
Fri Jun 16 02:18:26 EDT 2006
Hi Daniel,
we're facing exactly the same problems you described. Swapping of dll-files
is enough to make previously working maps totally unfunctional. Maps based
on oracle spatial, shapefiles or MapInfo-files all give an Apache related
message "Internal Server Error". Last row in the error.log states "Premature
end of script headers: mapserv.exe".
I can get errors from MapServer if I break the syntax in map-file, and
mistakes in SQL-statements raise errors from Oracle (connection is fine?).
Therefore I believe the problem is not related to .map-files or database at
all.
I'm wondering if this strange behaviour is somehow related to "wrong"
software environment. So far we have tested following combinations with no
luck:
MS4W v1.5.4 & Windows NT 4.0 & remote Oracle 10g R2 database
MS4W v2.0 & Windows NT 4.0 & remote Oracle 10g R2 database
MS4W v1.5.4 & Windows 2003 Server & local Oracle 10g R2 database
Maybe Jukka could tell what operating system he had in his successful
installation?
View this message in context: http://www.nabble.com/oracle-spatial-t1774461.html#a4895493
Sent from the Mapserver - User forum at Nabble.com.
