oracle spatial
Zhonghai Wang zhonghaiw at GMAIL.COM
Mon Jun 19 03:41:55 EDT 2006
Hi Daniel,
does MS4W1.5.3 work for your application with oracle? how did you do the DLL
swapping? can you give me some ideas how you did that? I've tried almost
with all the MS4W packages, and I can not get them work.
thanks
zhonghai
On 6/19/06, Daniel Goetz <madprof at gmx.ch> wrote:
> Hi Jeff,
> I installed the ms4w 1.5.3 package on my computer, did the .dll swapping
> and as you prompted everything works fine. I can show oracle data via "OGR"
> and via "native" mapserver supprot. And I can map all other file-based
> formats and can combine them with oracle spatial data.
> Thank you all so much for your help. I am really thankful for your
> assistance. Thank you.
> regards
> Daniel
> P.S. And please let me know, when the problems with the libmap.dll (for
> oracle support) in the ms4w 2.0 package are fixed. Thank you.
> -------- Original-Nachricht --------
> Datum: Fri, 16 Jun 2006 16:50:54 +0200
> Von: Zhonghai Wang <zhonghaiw at GMAIL.COM>
> An: MAPSERVER-USERS at LISTS.UMN.EDU
> Betreff: Re: [UMN_MAPSERVER-USERS] RE : oracle spatial
> > It's a little bit weird, I've test the version MS4W1.5.3 again, It also
> > does
> > not work. The same as MS4W2.0, with the command shp2img there is no
> > problem
> > to generate the map image. my MapFile contains both connectiontypes,
> this
> > is
> > the mapfile snippets:
> > LAYER
> >     NAME "SEARCHZIP POLYGON"
> >     TYPE POLYGON
> >     STATUS DEFAULT
> >     CONNECTIONTYPE ORACLESPATIAL
> >     CONNECTION "Ar/Ar at GIS2"
> >     DATA "GEOLOC FROM SEARCHZIP USING NONE"
> >     CLASS
> >       NAME "ZIPAREA"
> >       COLOR 153 153 153
> >     END
> >   END
> >   LAYER
> >     NAME "SEARCHCITY POLYGON"
> >     TYPE POLYGON
> >     STATUS DEFAULT
> >     CONNECTIONTYPE OGR
> >     CONNECTION "OCI:Ar/Ar at GIS2"
> >     DATA "SEARCHCITY"
> >     CLASS
> >       NAME "CITIES"
> >       COLOR 207 189 0
> >     END
> >   END
> > thanks for any hints to solve this problem.
> > zhonghai
> "Feel free" – 10 GB Mailbox, 100 FreeSMS/Monat ...
> Jetzt GMX TopMail testen: http://www.gmx.net/de/go/topmail
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060619/0a1361a1/attachment.html
