What's the catch with ROSA on Windows client PCs
Joaquim Pinto da Costa
jpintodacosta at GMAIL.COM
Tue Jun 20 12:14:50 EDT 2006
Philip thanks for the reply
On 6/20/06, Spot <spot.news at gmx.net> wrote:
> At the point when I became frustrated by ROSA I decided to use jBox
> instead. I did not have the blank screen problem, but I still think
> (with some limitations) it is the better choice. Did you try this?
No but I'll give it try, but not now :-)
> can be forced by switching to a different window and back to the browser
> window. Is the map then shown properly?
The site is always the same only the client behaviour changes. Some of
the clients indeed exhibited that behavior, you needed to move the
window to get the content, some kind of a redraw problem. On most PC
it works fine, after some JAVA is installed, but some of them
(including the one where I'm supposed to make a presentation) when
they decide not to work nothing seams to cure them.
Thanks
Joaquim
