Mapscript ,Mono, Apache and Linux : a great story
Tamas Szekeres
szekerest at GMAIL.COM
Wed Jun 21 17:36:54 EDT 2006
>I did not include your code at this time because (if i understood your last
>email, the modification was about the dynamic creation of LayerObjet
>object.
>My last answer was about this. I wrote that i disabled the function to make
>a test and i prodcued the same error with the getfeature
>Do you want that i make the test?
>Most of the error are on the getfeature function but not all.
Xavier,
If you aren't using dynamically created layerObj classObj and styleObj with
a parent object given in the constructor that change is not to be made.
>I get the problem when i'm connecting to the web site with my browser
You have several aspx files, what is the URL you are using?
>I can make an mono console application that create mapserver output file
and
>test the result
That would make the things much more easier.
Best Regards,
Tamas
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.394 / Virus Database: 268.9.2/372 - Release Date: 2006.06.21.
