Mapscript ,Mono, Apache and Linux : a great story
Xavier Mauclaire
xavier.mauclaire at GEOTER.FR
Wed Jun 21 18:12:26 EDT 2006
I'm going to use the dynamic layer so i'm going to update the source
what about installing the 4.6 version of mapserver on the linux server ?
The server scratches when i want to create a information form. This form is
launch by the flash program. It uses the web getparcellereglement.aspx
(client data(xml) are send using POST method) This verb is managed by the
GetParcelleReglement.cs class. This class initializes mapserver and computes
data. Finally it redirects to parcellereglement.aspx to display
informations.
I installed gaim to have discussion and i' connecting to the mapserver
forum. my alias is xavier34 regards
Xavier Mauclaire
Ingénieur Informaticien
GEOTER SAS
3, rue Jean Monnet
34830 Clapiers France
Tél.: +33 (0)4.67.59.18.11
Fax: +33 (0)4.67.59.18.24
Email: xavier.mauclaire at geoter.fr
Web site: http://www.geoter.fr
-----Message d'origine-----
De : Tamas Szekeres [mailto:szekerest at gmail.com] Envoyé : mercredi 21 juin
2006 23:37 À : 'Xavier Mauclaire'
Cc : MAPSERVER-USERS at lists.umn.edu
Objet : RE: [UMN_MAPSERVER-USERS] Mapscript ,Mono, Apache and Linux : a
great story
>I did not include your code at this time because (if i understood your
>last email, the modification was about the dynamic creation of
>LayerObjet object.
>My last answer was about this. I wrote that i disabled the function to
>make a test and i prodcued the same error with the getfeature Do you
>want that i make the test?
>Most of the error are on the getfeature function but not all.
Xavier,
If you aren't using dynamically created layerObj classObj and styleObj with
a parent object given in the constructor that change is not to be made.
>I get the problem when i'm connecting to the web site with my browser
You have several aspx files, what is the URL you are using?
>I can make an mono console application that create mapserver output
>file
and
>test the result
That would make the things much more easier.
Best Regards,
Tamas
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.1.394 / Virus Database: 268.9.2/372 - Release Date: 2006.06.21.
