[UNCLASSIFIED]RE: [UMN_MAPSERVER-USERS] dl(): Unable to load
dyna mic library
ramesh karra
karrarm at YAHOO.COM
Thu Jun 22 01:35:20 EDT 2006
Thanks Antti!
I tried setting LD_LIBRARY_PATH in php.ini and it did
not work.
If were to have a web-site hosted by some web-hosting
company, how can I do it? Obviously, in that case I
would have root or apache access.
I think my current problem is similar to that.
In general, what is the right way to host a web-site
using mapserver?
Thanks
Ramesh
--- Antti Roppola <Antti.Roppola at BRS.GOV.AU> wrote:
> Hi all,
> You must have root access to alter the linker cache.
> Without access to root or Apache, pretty much the
> only option
> is to use putenv() to set LD_LIBRARY_PATH. In order
> to do this,
> you'll need to alter php.ini to allow putenv to set
> LD_LIBRARY_PATH.
> I stress that there are serious security issues to
> ponder before
> changing this default behaviour. After all, a
> compromised PHP page
> could then be used to link against compromised
> libraries that have
> been uploaded to the server.
> My preference would be to try set LD_LIBRARY_PATH in
> php.ini and see
> if that works.
> Antti
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of
> ramesh karra
> Sent: Thursday, 22 June 2006 2:05 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] dl(): Unable to
> load dynamic library
> No. I did not.
> Do you mean that I should add my library path to
> /etc/ld.so.conf and then do 'ldconfig'?
> What if I do not have the superuser permissions?
> Ramesh
> IMPORTANT - This message has been issued by The
> Department of Agriculture, Fisheries and Forestry
> (DAFF). The information transmitted is for the use
> of the intended recipient only and may contain
> confidential and/or legally privileged material. It
> is your responsibility to check any attachments for
> viruses and defects before opening or sending them
> on.
> Any reproduction, publication, communication,
> re-transmission, disclosure, dissemination or other
> use of the information contained in this e-mail by
> persons or entities other than the intended
> recipient is prohibited. The taking of any action
> in reliance upon this information by persons or
> entities other than the intended recipient is
> prohibited. If you have received this e-mail in
> error please notify the sender and delete all copies
> of this transmission together with any attachments.
> If you have received this e-mail as part of a valid
> mailing list and no longer want to receive a message
> such as this one advise the sender by return e-mail
> accordingly. Only e-mail correspondence which
> includes this footer, has been authorised by DAFF
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
