Mapscript ,Mono, Apache and Linux : a great story
Xavier Mauclaire xavier.mauclaire at GEOTER.FR
Thu Jun 22 09:37:58 EDT 2006
Tamas
This program has been created with VS2003. Under windows (.net) it works
well.
It has been compiled under linux with mono (file compile.sh) and tested
under linux too. When running under linux it  doesn't not work
For the error you get, change, in the mapfile test.map the line IMAGETYPE
swf By IMAGETYPE png
Mapserver a been compiled with the swf option
Do you want to have a chat on IRC?
regards
Xavier Mauclaire
Service informatique
GEOTER SAS
3, rue Jean Monnet
34830 Clapiers France
Tél.: +33 (0)4.67.59.18.11
Fax: +33 (0)4.67.59.18.24
Email: xavier.mauclaire at geoter.fr
Web site: http://www.geoter.fr
-----Message d'origine-----
De : Tamas Szekeres [mailto:szekerest at gmail.com] Envoyé : jeudi 22 juin 2006
13:53 À : Xavier Mauclaire Objet : Re: [UMN_MAPSERVER-USERS] Mapscript
Hi Xavier,
I 've tested on windows and i got:
loadOutputFormat(): General error message. OUTPUTFORMAT clause
references driver SWF, but this driver isn't configured.     at
mapObj..ctor(String filename)
   at Test1.Form1.button1_Click(Object sender, EventArgs e) in
c:\cvs\xavier\test\test\form1.cs:line 124
using your mapscript_csharp.dll. I am not so familiar with swf so give me
some help.
I am a bit confused whether you are tesing on windows or linux.
regards,
Tamas
PS: I could not identify you on the mapserver IRC line :(
2006/6/22, Xavier Mauclaire <xavier.mauclaire at geoter.fr>:
> Hi tamas
> You will find joined the file test.zip containing a little forms
> programs using the mapserver getfeature function In the interface,
> when you click on the button, the programs scratches like Mapserver.
> You will notce that the code is not very clean (sorry).
> Thre is another problem if i want to access séquentially to each
> feature of a layer. If i use a while loop with testing the value of
> the spaheObj returned by the function getfeature,this loop is infinite
> because this function always returns a non NULL value. I saw this problem
with windows.
> This is why i used a for loop.
> regards
> Xavier Mauclaire
> GEOTER SAS
> 3, rue Jean Monnet
> juin 2006 00:45 À : 'Xavier Mauclaire'
> Objet : RE: [UMN_MAPSERVER-USERS] Mapscript ,Mono, Apache and Linux :
> a great story
> I'm afraid i not understand exactly your application model. I am not
> falmiliar with flash.
> Could you explain the usage sequence in more detail and the steps to
> test this problem?
> I will trying look into it tomorrow then.
> How should i configure apache for your app?
> Tamas
> -----Original Message-----
> From: Xavier Mauclaire [mailto:xavier.mauclaire at geoter.fr]
> Sent: Thursday, June 22, 2006 12:02 AM
> To: 'Tamas Szekeres'
> Subject: RE: [UMN_MAPSERVER-USERS] Mapscript ,Mono, Apache and Linux :
> a great story
> I'm going to use the dynamic layer so i'm going to update the source
>  what about installing the 4.6 version of mapserver on the linux server ?
> The server scratches when i want to create a information form. This
> form is launch by the flash program. It uses the web
> getparcellereglement.aspx (client data(xml) are send using POST
> method) This verb is managed by the GetParcelleReglement.cs class.
> This class initializes mapserver and computes data. Finally it
> redirects to parcellereglement.aspx to display informations.
> I installed gaim to have discussion and i' connecting  to the
> mapserver forum. my alias is xavier34 regards
> Xavier Mauclaire
> Ingénieur Informaticien
> GEOTER SAS
> 3, rue Jean Monnet
> De : Tamas Szekeres [mailto:szekerest at gmail.com] Envoyé : mercredi 21
> juin
> 2006 23:37 À : 'Xavier Mauclaire'
> Cc : MAPSERVER-USERS at lists.umn.edu
> a great story
> >I did not include your code at this time because (if i understood
> >your last email, the modification was about the dynamic creation of
> >LayerObjet object.
> >My last answer was about this. I wrote that i disabled the function
> >to make a test and i prodcued the same error with the getfeature Do
> >you want that i make the test?
> >Most of the error are on the getfeature function but not all.
> Xavier,
> If you aren't using dynamically created layerObj classObj and styleObj
> with a parent object given in the constructor that change is not to be
made.
> >I get the problem when i'm connecting to the web site with my browser
> You have several aspx files, what is the URL you are using?
> >I can make an mono console application that create mapserver output
> >file
> and
> >test the result
> That would make the things much more easier.
> Best Regards,
> Tamas
> No virus found in this outgoing message.
> Checked by AVG Free Edition.
> Version: 7.1.394 / Virus Database: 268.9.2/372 - Release Date: 2006.06.21.
> No virus found in this incoming message.
