msWMSLoadGetParams
Alexander Rodríguez Torres
atorres at ESTUDIANTES.UCI.CU
Thu Jun 22 11:12:24 EDT 2006
I receive this error when I try load my map
msWMSLoadGetMapParams():Invalid SRS given:SRS must be valid for all
request layers
Somebody can help me????
This is my .map
MAP
NAME "Mapa de la UCI"
STATUS ON
EXTENT 9387137.4 805683.77 10119140.81 1507910.77
SIZE 500 500
SHAPEPATH "/var/www/localhost/htdocs/MapaPost/data"
SYMBOLSET "/var/www/localhost/htdocs/MapaPost/etc/symbols.sym"
FONTSET "/var/www/localhost/htdocs/MapaPost/etc/fonts.txt"
IMAGETYPE PNG
IMAGECOLOR 174 183 207
UNITS METERS
TEMPLATEPATTERN "UCI"
WEB
MINSCALE 259371
IMAGEPATH "/temp/"
TEMPLATE mapa.html
HEADER mapa_header.html
IMAGEURL "/temp/"
END
REFERENCE
STATUS ON
IMAGE "/var/www/localhost/htdocs/MapaPost/images/keymap.png"
SIZE 88 69
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
MINBOXSIZE 3
MAXBOXSIZE 0
MARKER 0
MARKERSIZE 0
END
QUERYMAP
STATUS OFF
SIZE -1 -1
COLOR 255 0 0
STYLE HILITE
END
# Start of legend object
LEGEND
STATUS ON
IMAGECOLOR 255 255 255
POSITION LL
KEYSIZE 18 12
KEYSPACING 5 5
TEMPLATE "ttt"
LABEL
TYPE BITMAP
SIZE MEDIUM
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 89
PARTIALS TRUE
FORCE FALSE
END
END
# Start of scalebar object
SCALEBAR
STATUS ON
COLOR 255 255 255
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 0 0 0
UNITS KILOMETERS
INTERVALS 5
SIZE 150 5
STYLE 0
POSITION LL
LABEL
TYPE BITMAP
SIZE SMALL
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
PARTIALS TRUE
FORCE TRUE
END
END
# Start of OutputFormat object
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE PC256
TRANSPARENT FALSE
END
LAYER
NAME "Contornos"
STATUS ON
CONNECTIONTYPE POSTGIS
CONNECTION "user=postgres dbname=siguci host=localhost"
CLASSITEM "the_geom"
DATA "the_geom from contornos"
TYPE POLYGON
CLASS
NAME "contornos"
TEMPLATE ""
STYLE
SYMBOL 0
COLOR 0 128 0
OUTLINECOLOR 0 0 0
END
END
END
LAYER
NAME "Viales"
STATUS ON
DATA "the_geom from viales"
TYPE LINE
CLASS
NAME "viales"
TEMPLATE ""
STYLE
SYMBOL 0
COLOR 255 0 0
OUTLINECOLOR 0 0 0
END
END
END
LAYER
NAME "Areas deportivas"
STATUS ON
DATA "the_geom from areasdeportivas"
TYPE POLYGON
CLASS
NAME "areasdeportivas"
TEMPLATE "deportivas.html"
STYLE
SYMBOL 0
COLOR 255 255 0
OUTLINECOLOR 0 0 0
END
END
#HEADER "deportivas_header.html"
END
LAYER
NAME "Separadores"
STATUS ON
DATA "the_geom from separadores"
TYPE POLYGON
CLASS
NAME "separadores"
TEMPLATE ""
STYLE
SYMBOL 0
COLOR 0 128 0
OUTLINECOLOR 0 0 0
END
END
END
LAYER
NAME "Manzanas"
STATUS ON
DATA "the_geom from manzanas"
TYPE POLYGON
CLASS
NAME "manzanas"
TEMPLATE "manzanas.html"
STYLE
SYMBOL 0
COLOR 255 232 208
OUTLINECOLOR 0 0 0
END
END
#HEADER "manzanas_header.html"
# FOOTER "manzanas_footer.html"
END
LAYER
NAME "Edificios"
STATUS ON
DATA "the_geom from edificios"
TYPE POLYGON
CLASS
NAME "edificios"
TEMPLATE "edificios.html"
STYLE
SYMBOL 0
COLOR 192 192 192
OUTLINECOLOR 0 0 0
END
END
#HEADER "edificios_header.html"
#FOOTER "edificios_footer.html"
END
END
Ing. Alexander Rodriguez Torres.
Universidad de las Ciencias Informaticas.
E-Mail:atorres at estudiantes.uci.cu
