Mapserver <-> SDE Joins
Adam Quiney
aquiney at REFRACTIONS.NET
Thu Jun 22 15:20:01 EDT 2006
Hi all,
We're putting together an application that uses Mapserver to connect to
an ArcSDE instance running against an SQLServer back-end.
Are joins (i.e.
http://mapserver.gis.umn.edu/docs/reference/mapfile/join) supported with
ArcSDE connections? I know the ArcSDE page says "on-the-fly" joins are
not supported, but I wasn't sure if those referred to the same thing or
some other SDE-specific join?
We are currently storing a set of address points in our database. We
also have a many-to-one relationship between these address points and
any number of aliases that they could hold. We would like to be able to
perform a join between each address point and all of its aliases. Is
this possible on mapserver's end, or are we limited to creating a view
in SDE that will support this?
Lastly, if this *can* be done in mapserver, is it possible to flatten
out the aliases so that the final feature that is displayed to the
browser (and that would be queried upon a get-feature-info request)
would have all of the attributes of the address point, along with an
attribute for each attached alias (the alternative being that we have
one address point/alias feature for each address point and alias pair).
Thanks,
--Adam
