C# MapScript - Extent of mapObj not set after object creation
Tamas Szekeres szekerest at GMAIL.COM
Thu Jun 22 19:05:21 EDT 2006
I have tested your code and worked for me. Would you compile the latest
mapserver + mapscript and test with those binaries?
This is not my bug tracking day :-((
Regards,
Tamas
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Hong
Sent: Thursday, June 22, 2006 11:54 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] C# MapScript - Extent of mapObj not set
On Thu, Jun 22, 2006 at 09:47:57PM +0200, Tamas Szekeres wrote:
> Hi,
> Are the other parameters correct like p_map.name?
As far as I can tell, other parameters seem to be correct. The parameter
p_map.name is correct.
> Could you post a bug report attaching the sample code and the map file?
Done. Bug# 1807.
Thank you.
> Behalf Of Hong
> Sent: Thursday, June 22, 2006 8:42 PM
> Subject: [UMN_MAPSERVER-USERS] C# MapScript - Extent of mapObj not set
after
> object creation
> Hello,
> I have experienced problem using C# MapScript where I tried to create a
> mapObj
> using the mapObj constructor from a map file, after the object creation,
the
> extent are not set properly.
> The mapfile "odessa.map" is as follows.
> NAME ODESSA
> STATUS on
> SIZE 684 592
> EXTENT -104.10235082418987 29.77884364609445 -101.64625194665918
> 32.52517088808842
> I used VB.NET to create the object:
> Dim p_map as mapObj = new mapObj("odessa.map")
> Tracking p_map through a debugger after object creation revealed that:
> p_map.extent.minx, p_map.extent.miny, p_map.extent.maxx, p_map.extent.maxy
> still have values of 0.0.
> My development environment:
> - MS Visual Studio 2003 (VB.NET)
> - DLLs (mapscript_csharp.dll, mapscript.dll, etc) from MS4W PHP4 Base
>   Installer v1.5.4
> - MS Windows XP Pro with IIS 5
> - .NET Framework 1.1
> This did not happen with older version of DLLs for MapServer 4.6.
> Has anyone else also used C# MapScript but with VB.NET as the programming
> language?
> Any help/suggestion appreciated.
> Hong
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.1.394 / Virus Database: 268.9.2/373 - Release Date: 2006.06.22.
> No virus found in this outgoing message.
