msWMSLoadGetParams
Marcos Cobeña marcoscobena at GMAIL.COM
Fri Jun 23 06:46:22 EDT 2006
Hi Alexander,
I think you should use PROJECTION tag to define projection used in
your different layers. Something like:
PROJECTION
		"init=EPSG:4031"
END
We'll be waiting for your feedback, good luck!
Regards,
2006/6/22, Alexander Rodríguez Torres <atorres at estudiantes.uci.cu>:
> I receive this error when I try load my map
> msWMSLoadGetMapParams():Invalid SRS given:SRS must be valid for all
> request layers
> Somebody can help me????
> This is my .map
> MAP
>   NAME "Mapa de la UCI"
>   STATUS ON
>   EXTENT 9387137.4 805683.77 10119140.81 1507910.77
>   SIZE 500 500
>   SHAPEPATH "/var/www/localhost/htdocs/MapaPost/data"
>   SYMBOLSET "/var/www/localhost/htdocs/MapaPost/etc/symbols.sym"
>   FONTSET "/var/www/localhost/htdocs/MapaPost/etc/fonts.txt"
>   IMAGETYPE PNG
>   IMAGECOLOR 174 183 207
>   UNITS METERS
>   TEMPLATEPATTERN "UCI"
>   WEB
>     MINSCALE 259371
>     IMAGEPATH "/temp/"
>     TEMPLATE mapa.html
>     HEADER mapa_header.html
>     IMAGEURL "/temp/"
>      END
>   REFERENCE
>     STATUS ON
>     IMAGE "/var/www/localhost/htdocs/MapaPost/images/keymap.png"
>     SIZE 88 69
>     COLOR -1 -1 -1
>     OUTLINECOLOR 255 0 0
>     MINBOXSIZE 3
>     MAXBOXSIZE 0
>     MARKER 0
>     MARKERSIZE 0
>   END
>   QUERYMAP
>     STATUS OFF
>     SIZE -1 -1
>     COLOR 255 0 0
>     STYLE HILITE
>   END
>   # Start of legend object
>   LEGEND
>     STATUS ON
>     IMAGECOLOR 255 255 255
>     POSITION LL
>     KEYSIZE 18 12
>     KEYSPACING 5 5
>     TEMPLATE "ttt"
>     LABEL
>       TYPE BITMAP
>       SIZE MEDIUM
>       OFFSET 0 0
>       BUFFER 0
>       MINDISTANCE -1
>       MINFEATURESIZE -1
>       COLOR 0 0 89
>       PARTIALS TRUE
>       FORCE FALSE
>     END
>   END
>   # Start of scalebar object
>   SCALEBAR
>     STATUS ON
>     COLOR 255 255 255
>     OUTLINECOLOR 0 0 0
>     BACKGROUNDCOLOR 0 0 0
>     UNITS KILOMETERS
>     INTERVALS 5
>     SIZE 150 5
>     STYLE 0
>     POSITION LL
>     LABEL
>       TYPE BITMAP
>       SIZE SMALL
>       OFFSET 0 0
>       BUFFER 0
>       MINDISTANCE -1
>       MINFEATURESIZE -1
>       COLOR 0 0 0
>       PARTIALS TRUE
>       FORCE TRUE
>     END
>   END
>   # Start of OutputFormat object
>   OUTPUTFORMAT
>     NAME "png"
>     MIMETYPE "image/png"
>     DRIVER "GD/PNG"
>     EXTENSION "png"
>     IMAGEMODE PC256
>     TRANSPARENT FALSE
>   END
>   LAYER
>     NAME "Contornos"
>     STATUS ON
>     CONNECTIONTYPE POSTGIS
>     CONNECTION "user=postgres dbname=siguci host=localhost"
>     CLASSITEM "the_geom"
>     DATA "the_geom from contornos"
>     TYPE POLYGON
>     CLASS
>       NAME "contornos"
>       TEMPLATE ""
>       STYLE
>         SYMBOL 0
>         COLOR 0 128 0
>         OUTLINECOLOR 0 0 0
>       END
>     END
>   END
>   LAYER
>     NAME "Viales"
>     STATUS ON
>     DATA "the_geom from viales"
>     TYPE LINE
>     CLASS
>       NAME "viales"
>       TEMPLATE ""
>       STYLE
>         SYMBOL 0
>         COLOR 255 0 0
>         OUTLINECOLOR 0 0 0
>       END
>     END
>   END
>   LAYER
>     NAME "Areas deportivas"
>     STATUS ON
>     DATA "the_geom from areasdeportivas"
>     TYPE POLYGON
>     CLASS
>       NAME "areasdeportivas"
>       TEMPLATE "deportivas.html"
>       STYLE
>         SYMBOL 0
>         COLOR 255 255 0
>         OUTLINECOLOR 0 0 0
>       END
>     END
>     #HEADER "deportivas_header.html"
>   END
>   LAYER
>     NAME "Separadores"
>     STATUS ON
>     DATA "the_geom from separadores"
>     TYPE POLYGON
>     CLASS
>       NAME "separadores"
>       TEMPLATE ""
>       STYLE
>         SYMBOL 0
>         COLOR 0 128 0
>         OUTLINECOLOR 0 0 0
>       END
>     END
>   END
>   LAYER
>     NAME "Manzanas"
>     STATUS ON
>     DATA "the_geom from manzanas"
>     TYPE POLYGON
>     CLASS
>       NAME "manzanas"
>       TEMPLATE "manzanas.html"
>       STYLE
>         SYMBOL 0
>         COLOR 255 232 208
>         OUTLINECOLOR 0 0 0
>       END
>     END
>     #HEADER "manzanas_header.html"
>    # FOOTER "manzanas_footer.html"
>   END
>   LAYER
>     NAME "Edificios"
>     STATUS ON
>     DATA "the_geom from edificios"
>     TYPE POLYGON
>     CLASS
>       NAME "edificios"
>       TEMPLATE "edificios.html"
>       STYLE
>         SYMBOL 0
>         COLOR 192 192 192
>         OUTLINECOLOR 0 0 0
>       END
>     END
>     #HEADER "edificios_header.html"
>     #FOOTER "edificios_footer.html"
>   END
> END
> Ing. Alexander Rodriguez Torres.
>  Universidad de las Ciencias Informaticas.
>   E-Mail:atorres at estudiantes.uci.cu
Marcos - http://www.youcannoteatbits.org
