query raster layer
Giorgio Libertà
giorgio.liberta at JRC.IT
Fri Jun 23 07:52:08 EDT 2006
Dear Frank,
Thank you for your replay.
For the moment I can not give you access to this part because I am
developing
this new functionality and the all stuff is on my intranet. Sorry.
But anyway to give you more info:
1. I am using mapserver 4.8.3 with GDAL 1.2.6
2. the url example is
dev-effis.h07.jrc.it/mapserv/WmsEffis?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&LAYERS=landcover&QUERY_LAYERS=landcover&FEATURE_COUNT=100&BBOX=-7.366837147853632,32.29370224938404,10.613480010522485,50.02771369326186&WIDTH=730&HEIGHT=720&X=192&Y=488&INFO_FORMAT=text/html
3. when I use the GetCapabilities the layer 'landcover' is queryable=1
thx & ciao
Frank Warmerdam wrote:
> Giorgio Libertà wrote:
>> the raster file is a compressed tif generated using GDAL utils.
>> When I try a WMS GetFeatureInfo I got the following error:
>> <ServiceExceptionReport version="1.1.1">
>> <ServiceException>
>> msDrawShape(): General error message. Unknown layer type.
>> </ServiceException>
>> </ServiceExceptionReport>
>> Please can you help me. What's wrong with my layer?
>> Maybe the definition is not complete?
> Giorgio,
> I implemented the raster query support, and I never tested using it
> to support a WMS GetFeatureInfo. I suspect the code isn't setup properly
> to handle it. However, it would help if you gave more detail. What
> was your exact GetFeatureInfo request for instance? Ultimately, if you
> would like me to look into it in detail you will need to provide a
> mapfile, supporting data, and the exact url I can use to invoke
> mapserver to reproduce the problem.
> Best regards,
Giorgio Libertà
European Commission - DG Joint Research Center
Institute for Environment and Sustainability
Land Management & Natural Hazards Unit
TP 261, via Fermi
Ispra (VA), 21020 Italy
e-mail: giorgio.liberta at jrc.it
Phone: +39 0332 785309
Fax: +39 0332 789074
Mobile: +39 340 2566207
The views expressed are purely those of the writer and may not in
any circumstances be regarded as stating an official position of
the European Commission.
