WMS Layer Problem
Brock Anderson
banders at REFRACTIONS.NET
Mon Jun 26 11:50:19 EDT 2006
I made a WMS request in my browser using the request parameters
specified in your photo layer:
http://terraservice.net/OgcMap.ashx?request=getmap&service=wms&version=1.1.1&width=500&height=500&layers=DOQ&bbox=-170,60,-150,75&srs=EPSG:4326&format=png
The WMS gave an error: "Invalid Lon-Lat coordinates, must specify at
least one (lon,lat) pair correctly; Longitude must be between -170 and
-60 Latitude must be between 15 and 75 "
With a different lat-long bounding box it seems to work. I tested with
bbox=-124,46,-110,52. I think the source WMS server doesn't like your
bounding box.
That's just a guess. I don't know exactly what WMS URLs mapserver is
using to request the photo layers. If you have a way to intercept those
outgoing URLs that should give you enough clues to fix the problem.
Brock
M.L. Jackson wrote:
> Hi, I'm new to the Mapserver Listserv. I am having problems displaying
> the wms layer on my map. My problem is that I don't see any aerial
> shots at all. It is as if the map is being drawn without the layer.
> Here is a snippet out of my map file where the wms layer is defined:
> LAYER
> NAME "photo"
> STATUS DEFAULT
> TYPE RASTER
> MINSCALE 10000
> #MAXSCALE 10000
> CONNECTIONTYPE WMS
> CONNECTION "http://terraservice.net/OgcMap.ashx?"
> METADATA
> "wms_srs" "EPSG:4326"
> "wms_title" "Orthophoto"
> "wms_name" "DOQ"
> "wms_server_version" "1.1.1"
> "wms_format" "image/png"
> "wms_layers" "doq"
> "wms_group_title" "background"
> "wms_onlineresource" "http://terraservice.net/OgcMap.ashx?"
> "wms_latlonboundingbox" "-170 -60 15 75"
> #"wms_connectiontimeout" "120"
> END
> PROJECTION
> "init=epsg:4326"
> END
> DEBUG ON
> END
> BTW, my map extent is -178.21759836236586 18.924781799316406
> -66.96927103600244 71.40623535327121. Thanks for your reply.
> _________________________________________________________________
> Don’t just search. Find. Check out the new MSN Search!
> http://search.msn.click-url.com/go/onm00200636ave/direct/01/
