WMS Layer Problem
M.L. Jackson
mljacks2 at HOTMAIL.COM
Mon Jun 26 14:40:01 EDT 2006
Is the MINSCALE property necessary?
>From: Brock Anderson <banders at refractions.net>
>To: "M.L. Jackson" <mljacks2 at HOTMAIL.COM>
>CC: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] WMS Layer Problem
>Date: Mon, 26 Jun 2006 09:45:31 -0700
>Check your tomcat logs for incoming requests for the WMS photo service.
>Those will give clues. I suspect you'll find that the requests are using
>bboxes that are too large for your photo service. (Your photo service seems
>to reject requests with bboxes larger than the extents of the DOQ layer.
>It's a bit finicky, and you may have to work around that. Perhaps increase
>the extents of your photo service.)
>Brock
>M.L. Jackson wrote:
>>Actually, I'm using the bbox range that you indicated in your other reply
>>and still not getting a wms layer image. That error message that I posted
>>is old. I just thought that it might indicate a problem because I haven't
>>changed much since then.
>>>From: Brock Anderson <banders at REFRACTIONS.NET>
>>>Reply-To: Brock Anderson <banders at REFRACTIONS.NET>
>>>To: MAPSERVER-USERS at LISTS.UMN.EDU
>>>Date: Mon, 26 Jun 2006 09:26:25 -0700
>>>Yes, that URL from the Tomcat log is probably the one that Mapserver used
>>>to request the photo layer.
>>>Recall the error message I mentioned before said "Invalid Lon-Lat
>>>coordinates, must specify at least one (lon,lat) pair correctly;
>>>Longitude must be between -170 and -60 Latitude must be between 15 and 75
>>>". The bbox in your URL is outside that range.
>>>Brock
>>>M.L. Jackson wrote:
>>>>Thanks for the reply. I tried changing the bounding box and still
>>>>nothing. I even removed all the layers except the wms layer to make sure
>>>>it wasn't any conflict with the other layers.
>>>>I noticed this message in red after I stopped the Tomcat server. It has
>>>>only appeared a few times after stopping the server.
>>>>HTTP: Starting to prepare HTTP requests.
>>>>HTTP request: id=2,
>>>>http://terraservice.net/OgcMap.ashx?LAYERS=DOQ&REQUEST=GetMap&SERVICE=WMS&FORMAT=image%2Fpng&STYLES=&HEIGHT=600&VERSION=1.1.1&SRS=EPSG:4326&WIDTH=800&BBOX=%2D178%2E217598362366%2C3%2E44738582890752%2C%2D66%2E9692710360024%2C86%2E8836313236801&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
>>>>HTTP: Before download loop
>>>>msHTTPWriteFct(id=2, 396 bytes)
>>>>HTTP: After download loop
>>>>msHTTPExecuteRequests() timing summary per layer (connect_time +
>>>>time_to_first_packet + download_time = total_time in seconds)
>>>>Layer 2: 0.062 + 0.703 + 0.062 = 0.827s
>>>>msDrawRasterLayerLow(photo): entering.
>>>>Do you think that it is possible that the url for this layer is somehow
>>>>being requested exactly how it appears in this Tomcat message?
>>>>>Date: Mon, 26 Jun 2006 08:50:19 -0700
>>>>>I made a WMS request in my browser using the request parameters
>>>>>specified in your photo layer:
>>>>>http://terraservice.net/OgcMap.ashx?request=getmap&service=wms&version=1.1.1&width=500&height=500&layers=DOQ&bbox=-170,60,-150,75&srs=EPSG:4326&format=png
>>>>>The WMS gave an error: "Invalid Lon-Lat coordinates, must specify at
>>>>>least one (lon,lat) pair correctly; Longitude must be between -170 and
>>>>>-60 Latitude must be between 15 and 75 "
>>>>>With a different lat-long bounding box it seems to work. I tested with
>>>>>bbox=-124,46,-110,52. I think the source WMS server doesn't like your
>>>>>bounding box.
>>>>>That's just a guess. I don't know exactly what WMS URLs mapserver is
>>>>>using to request the photo layers. If you have a way to intercept those
>>>>>outgoing URLs that should give you enough clues to fix the problem.
>>>>>Brock
>>>>>M.L. Jackson wrote:
>>>>>>Hi, I'm new to the Mapserver Listserv. I am having problems displaying
>>>>>>the wms layer on my map. My problem is that I don't see any aerial
>>>>>>shots at all. It is as if the map is being drawn without the layer.
>>>>>>Here is a snippet out of my map file where the wms layer is defined:
>>>>>>LAYER
>>>>>>NAME "photo"
>>>>>>STATUS DEFAULT
>>>>>>TYPE RASTER
>>>>>>MINSCALE 10000
>>>>>>#MAXSCALE 10000
>>>>>>CONNECTIONTYPE WMS
>>>>>>CONNECTION "http://terraservice.net/OgcMap.ashx?"
>>>>>>METADATA
>>>>>>"wms_srs" "EPSG:4326"
>>>>>>"wms_title" "Orthophoto"
>>>>>>"wms_name" "DOQ"
>>>>>>"wms_server_version" "1.1.1"
>>>>>>"wms_format" "image/png"
>>>>>>"wms_layers" "doq"
>>>>>>"wms_group_title" "background"
>>>>>>"wms_onlineresource" "http://terraservice.net/OgcMap.ashx?"
>>>>>>"wms_latlonboundingbox" "-170 -60 15 75"
>>>>>>#"wms_connectiontimeout" "120"
>>>>>>END
>>>>>>PROJECTION
>>>>>>"init=epsg:4326"
>>>>>>END
>>>>>>DEBUG ON
>>>>>>END
>>>>>>BTW, my map extent is -178.21759836236586 18.924781799316406
>>>>>>-66.96927103600244 71.40623535327121. Thanks for your reply.
>>>>>>_________________________________________________________________
>>>>>>Dont just search. Find. Check out the new MSN Search!
>>>>>>http://search.msn.click-url.com/go/onm00200636ave/direct/01/
>>Express yourself instantly with MSN Messenger! Download today - it's FREE!
>>http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
On the road to retirement? Check out MSN Life Events for advice on how to
get there! http://lifeevents.msn.com/category.aspx?cid=Retirement
