WMS and SRS issue: "Invalid SRS given : SRS must be valid for
all requested layers."
Marcos Cobeña
marcoscobena at GMAIL.COM
Wed Jun 28 07:28:12 EDT 2006
Hi Frank,
Thank you so much for your help, I tried that but, eventhough it
doesn't crash anymore, it still doesn't paint the shapes.
Under ArcView, my shapes (SHP) are using this projection:
"+proj=longlat +ellps=WGS84 +no_defs"
, which, in my epsg projection file used, corresponds to:
# Unknown datum based upon the WGS 84 ellipsoid
<4030> +proj=longlat +ellps=WGS84 +no_defs no_defs <>
Why then I still don't see shapes painted?
Just in case, my MAP file:
# DGIS_12c.map
MAP
NAME DGIS
STATUS ON
SIZE 800 475
# "Huelva, Spain " lat=37.258335, lon=-6.9508333
EXTENT -180 -90 180 90 # 187889.12817030 4092316.51133811
197493.65136571 4099997.10096501 # 36.258335 -7.9508333 38.258335
-5.9508333
UNITS METERS
SHAPEPATH "Data"
IMAGECOLOR 255 255 255
IMAGETYPE PNG
CONFIG "PROJ_LIB" "C:\Archivos de programa\Apache Software
Foundation\Apache2.2\cgi-bin\DGIS\Data\Proj" # "C:\Documents and
Settings\Marcos\Escritorio\Temporal\Sistema de Información Geográfica
de Doñana (DGIS)\ms4w_2.0\ms4w\proj\nad"
WEB
METADATA
"wms_title" "Sistema de Información Geográfica de Doñana (DGIS)"
# http://localhost:8080/cgi-bin/DGIS/mapserv.exe?map=DGIS_12c.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
"wms_onlineresource"
"http://localhost:8080/cgi-bin/DGIS/mapserv.exe?map=DGIS_12c.map&"
"wms_srs" "EPSG:4326" # "EPSG:4269 EPSG:4326"
END
END
PROJECTION
"init=EPSG:4326"
END
LAYER
NAME "12c_linea"
TYPE LINE
STATUS ON
DATA Data/12c/12c_linea
CLASS
NAME "12c_linea"
COLOR 0 0 0
END
METADATA
"wms_title" "12c_linea"
# "wms_srs" "EPSG:4326 EPSG:4030"
"wms_format" "image/png"
END
END
Thanks in advance.
Regards,
2006/6/22, Frank Warmerdam <warmerdam at pobox.com>:
> Marcos Cobeña wrote:
> > Hi all,
> > I'm trying to access to a layer made of SHP files, like this one:
> > METADATA
> > "wms_srs" "EPSG:4326" # "EPSG:4031"
> > END
> > END
> > END
> > , where I've defined a projection ("init=EPSG:42304") and, for each
> > layer, its own SRS ("EPSG:4326"). It works fine, it draws my shape in
> > Canada (as expected with projections used).
> > Once I change main projection to 4030:
> > msWMSLoadGetMapParams(): Invalid SRS given : SRS must be valid for all
> > requested layers.
> Marcos,
> I have gone through the WMS validation code, and as I read it, you
> either have to list all legal request SRSes in the map's wms_srs metadata
> item or in all the requestable layers. So changing your layer wms_srs
> line to:
> ought to make it work.
> The error report isn't actually at the projections code, but rather
> in the code that validates what requests are legal according to your
> metadata.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGF, http://osgeo.org
Marcos - http://www.youcannoteatbits.org
