Oracle Spatial query problem
Fernando Simon
fsimon at UNIVALI.BR
Thu Jun 29 08:06:44 EDT 2006
As Frank hint the best way is increase the value of TEXT_SIZE
constant in the maporaclespatial.c and recompile the code.
This was define with this size to be equal with the max size than an
DBF can store in a column, but you can increase without problem.
Best regards.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://www.univali.br/g10 - UNIVALI/CTTMAR
Frank Warmerdam wrote:
> Mark Adams wrote:
>> We’re working with mapserver and PHP mapscript, we have a build of
>> mapserver that supports Oracle Spatial. We’re using Oracle 9i. Mostly
>> it is working fine, however we have discovered a fundamental problem,
>> not sure if this is a know design limitation or not. When we query a
>> layer that has the connection type "ORACLESPATIAL", if any of the
>> queried fields has a field VALUE length > 256 characters in any of
>> the queried records, we get the following error:
>> “<b>Fatal error</b>: [MapServer Error]:
>> msOracleSpatialLayerGetShape(): Error: ORA-1406: fetched column value
>> was truncated . Query statement: SELECT Field1, field2, field3,
>> Field4, field5, field6, Field7, field8, field9, Field10, field11,
>> field12, GEOM FROM MyTable WHERE Field1= 9506 .Check your data
>> statement.”
>> This error appears on the line:
>> $oShape = $Layer->getShape($oRes->tileindex,$oRes->shapeindex)
>> Note that it doesn’t matter what the actual field length is, if a
>> field is defined as varchar(4000) but the field value is only 250
>> characters it will work, but as soon as the value is greater than 256
>> characters it fails.
>> Is this a known limitation, or a bug? I’m hoping it can be resolved,
>> because if not it will blow up what was looking like a fine solution.
> Mark,
> Skimming the code, I believe you can increase the value of TEXT_SIZE near
> the beginning of maporaclespatial.c to increase this limit. Fernando
> Simon
> would need to give the final word on the best approach. I certainly feel
> that this ought to be handled more dynamically at some point.
> Looking into the OGR Oracle code, I'm not sure if it handles this
> properly
> either. It supports binding fields with widths larger than 256, but
> I'm not
> sure what it would do with a variable length field with no defined
> limit (if
> such things exist).
> Best regards,
