WMS and SRS issue: "Invalid SRS given : SRS must be valid for
all requested layers."
Frank Warmerdam
warmerdam at POBOX.COM
Thu Jun 29 09:53:14 EDT 2006
Marcos Cobeña wrote:
> Hi again Frank,
> Really thanks for your support, I think I've found the issue.
> Taking network dumps I've seen the query OpenLayers use:
> http://localhost:8080/cgi-bin/DGIS/mapserv.exe?bbox=-6.299999999999988,37.35000000000001,-5.849999999999988,37.80000000000001&width=256&height=256&map=DGIS_12c.map&layers=12c_linea&transparent=true&format=image/png&service=WMS&version=1.1.1&request=GetMap&styles=&exceptions=application/vnd.ogc.se_inimage&srs=EPSG:4326
> , which should draw some shapes, but it doesn't. Changing bbox values
> with those ones:
> http://localhost:8080/cgi-bin/DGIS/mapserv.exe?bbox=187889.12817030,4092316.51133811,197493.65136571,4099997.10096501&width=256&height=256&map=DGIS_12c.map&layers=12c_linea&transparent=true&format=image/png&service=WMS&version=1.1.1&request=GetMap&styles=&exceptions=application/vnd.ogc.se_inimage&srs=EPSG:4326
> , draws everything as expected. The issue, then, seems to be in the
> way we ask MS for the layer. Is there any way to tell MS to receive
> degree positions instead of the other ones?
Marcos,
Good sleuthing. The issue I believe is that MapServer does not know
enough about the coordinate system of it's data to properly reproject
things from whatever the projected coordinates are to lat/long. You
need to establish the true coordinate system of the data and properly
identify that in the .map file in a PROJECTION block on the layers.
The WMS request is correct since it indicates via SRS=EPSG:4326 that the
bbox is lat/long.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
