Invisible WMS layer??? Help please.
M.L. Jackson
mljacks2 at HOTMAIL.COM
Thu Jun 29 11:22:37 EDT 2006
I must have mistyped something or misunderstood. What service reports wms
request urls? I only ran across the url which seemed to be rarely and
randomly generated in Tomcat's output.
>From: Brock Anderson <banders at REFRACTIONS.NET>
>Reply-To: Brock Anderson <banders at REFRACTIONS.NET>
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] Invisible WMS layer??? Help please.
>Date: Wed, 28 Jun 2006 16:31:33 -0700
>Mapserver may be fairly silent about errors when it acts as a WMS client.
>Most likely the request that Mapserver sends to the other WMS server is
>failing somehow. I think you mentioned previously that you have direct
>access to the other WMS service (which mapserver uses as the source for its
>photo layer.) You can probably set that service up to report incoming WMS
>request URLs, and you can use those URLs to track down the problem.
>Brock
>M.L. Jackson wrote:
>>My wms layer does not display and it does not produce an error. This is
>>what my wms layer looks like:
>>LAYER
>>NAME "photo"
>>STATUS DEFAULT
>>TYPE RASTER
>>MINSCALE 10000
>>#MAXSCALE 10000
>>CONNECTIONTYPE WMS
>>CONNECTION "http://terraservice.net/OgcMap.ashx?"
>>METADATA
>>"wms_srs" "EPSG:4326"
>>"wms_title" "Orthophoto"
>>"wms_name" "DOQ"
>>"wms_server_version" "1.1.1"
>>"wms_format" "image/png"
>>"wms_layers" "doq"
>>"wms_group_title" "background"
>>"wms_onlineresource" "http://terraservice.net/OgcMap.ashx?"
>>"wms_latlonboundingbox" "-124 46 -110 52"
>>#"wms_connectiontimeout" "120"
>>END
>>PROJECTION
>>"init=epsg:4326"
>>END
>>DEBUG ON
>>END
>>I have debugging on and it has generated files for errors before. Whatever
>>is going on now is not producing an error file though. The mapserver
>>application comes up displaying the map as usual but no matter how far I
>>zoom into the map there are no aerial shots (via the wms layer). Any and
>>all help is appreciated.
>>_________________________________________________________________
>>Dont just search. Find. Check out the new MSN Search!
>>http://search.msn.click-url.com/go/onm00200636ave/direct/01/
FREE pop-up blocking with the new MSN Toolbar get it now!
http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
