Asynchrone clients? (continues vectordata retrieval / use
gdal directly?)
Eduard Witteveen
e.witteveen at HAWARIT.COM
Fri Jun 30 04:51:00 EDT 2006
Marcos Cobeña schreef:
>> Does anyone know a asynchrone (opensource) web-clients that retrieve
>> gisdata?
>> I would like to use a client that keeps retrieving data from the area,
>> but in which you can also click / pan / zoom in the meantime(with
>> keeping already loaded vector data).
> Give a try to OpenLayers (http://openlayers.org/), just cool. :-)
Thank you, this openlayers viewer really looks great. However, i want to
have the viewer running on vector data.
Currently we have a prototype-flashviewer(based upon the flash output of
mapserver), but due to the amount of data in the viewer, the rendering
becomes really slow (the conversion movie --> memory takes a lot of time)
>> If i would have to implement it i know it can be done by using the
>> "google" way of retrieving square's of data. Is there also a way to make
>> a streaming sollution with mapserver, or should i write my own server
>> using GDAL directly..(fetch objects around a certain coordinate with
>> ((distance to coordinate) * area) as order for which one to send first)
Maybe i should ask this question at the GDAL list?
Ing. Eduard Yeb Witteveen Software Engineer
Hawar Information Technology bv lid Dijkoraad Groep
De Wymerts 7 8701 WT Bolsward
Tel: +31 (0)515 570333 Fax: +31 (0)515 570335
http://www.hawarit.com/ nl_NL fy_NL en_US
