Shape layer is not shown. Please help
Travis Kirstine GIS Tech tkirstine at JDBARNES.COM
Wed Mar 1 11:07:36 EST 2006
Firstly, you should define a symbols.sym file that will be used to draw your
map symbols (points, lines, polygons)
It is declared in the map object just liike SHAPEPATH.  By default mapserver
will only draw points as one pixel if there is no
symbol defined
SYMBOLSET your path to the symbol.sym file    e.g.
/var/www/html/map_symbols/symbols.sym
open the symbol.sym file with a text editor and add the following
SYMBOL
   NAME 'circle'
   TYPE ELLIPSE
   FILLED TRUE
   POINTS
      1 1
    END
END
Save the file and close,  Add the following to your Brunnen CLASS in the
mapfile
    CLASS
        NAME "Brunnen"
        COLOR 255 0 0
        OUTLINECOLOR 0 255 0
        SYMBOL 'circle'
        SIZE 12
    END
Travis
  -----Original Message-----
  From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Baris YILMAZ
  Sent: Wednesday, March 01, 2006 9:46 AM
  To: MAPSERVER-USERS at LISTS.UMN.EDU
  Subject: [UMN_MAPSERVER-USERS] Shape layer is not shown. Please help
  I have a map file, which has two layers, one a raster layer, and the other
a shapefile. But the raster layer is shown whereas the layer Brunnen
(shapefile) is not shown. Can anyone help? I checked the path of the shape
file and it is ok.. Can anyone help me please? Is there anything missing in
the layer definitions of the layer "Brunnen"? My shapefile contains just
cross symbols.
  Thank you.
  Baris
  Below my mapfile;
  MAP
    EXTENT 3439438.15784499212000 5501464.74457754190000 3440160.4830
5511464.6416
    IMAGECOLOR 240 240 240
    IMAGETYPE png
    SHAPEPATH "C:/ms4w/apps/Data/KartenSHP/GWMshp/"
    SIZE 500 400
    STATUS ON
    UNITS METERS
    NAME "Hessischer Ried"
    OUTPUTFORMAT
      NAME "png"
      MIMETYPE "image/png"
      DRIVER "GD/PNG"
      EXTENSION "png"
      IMAGEMODE "PC256"
      TRANSPARENT FALSE
    END
    PROJECTION
      "proj=lcc"
      "lat_1=32"
      "lat_2=44"
      "lat_0=38"
      "lon_0=-100"
      "x_0=0"
      "y_0=0"
      "ellps=GRS80"
      "datum=NAD83"
    END
    LEGEND
        IMAGECOLOR 255 255 255
      KEYSIZE 20 10
      KEYSPACING 5 5
      LABEL
        SIZE MEDIUM
        TYPE BITMAP
        BUFFER 0
        COLOR 0 0 0
        FORCE FALSE
        MINDISTANCE -1
        MINFEATURESIZE -1
        OFFSET 0 0
        PARTIALS TRUE
      END
      POSITION LL
      STATUS EMBED
      TEMPLATE
"C:/ms4w/apps/maplab-2.2.1/htdocs/mapbrowser/legend_template.html"
    END
    QUERYMAP
        COLOR 255 255 0
      SIZE -1 -1
      STATUS OFF
      STYLE HILITE
    END
    SCALEBAR
        COLOR 0 0 0
      INTERVALS 4
      LABEL
        SIZE MEDIUM
        TYPE BITMAP
        BUFFER 0
        COLOR 0 0 0
        FORCE FALSE
        MINDISTANCE -1
        MINFEATURESIZE -1
        OFFSET 0 0
        PARTIALS TRUE
      END
      POSITION LL
      SIZE 200 3
      STATUS OFF
      STYLE 0
      UNITS MILES
    END
    WEB
      IMAGEPATH "C:/ms4w/tmp/ms_tmp/"
      IMAGEURL "/ms_tmp/"
        METADATA
        END
      QUERYFORMAT text/html
    END
    LAYER
      DATA "C:\ms4w\apps\Data\KartenSHP\Karten\TK25\60xx\6015SI_96.tif"
        METADATA
        END
      NAME "Ried"
      SIZEUNITS METERS
      STATUS ON
      TOLERANCEUNITS PIXELS
      TYPE RASTER
      UNITS METERS
    END
    LAYER
      NAME "Brunnen"
      STATUS DEFAULT
       DATA "Brunnen"
      TYPE POINT
      UNITS METERS
      SIZEUNITS PIXELS
       METADATA
      END
      PROJECTION
             "proj=lcc"
            "lat_1=32"
          "lat_2=44"
          "lat_0=38"
          "lon_0=-100"
          "x_0=0"
          "y_0=0"
          "ellps=GRS80"
          "datum=NAD83"
      END
      CLASS
          NAME "Brunnen"
      END
   END
  END
  Yahoo! Mail
  Bring photos to life! New PhotoMail makes sharing a breeze.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060301/15387914/attachment.html
