Oracle Spatial : Geodetic data : queries fail
Michael Scharber
mscharber at UCSD.EDU
Thu Mar 2 14:00:14 EST 2006
Fernando,
That did it. Thanks a bunch!
Michael
Michael Scharber
Scripps Institution of Oceanography
Institute of Geophysics and Planetary Physics
8785 Biological Grade
IGPP Room 4212
La Jolla, CA 92037
mscharber at gpsmail.ucsd.edu
(858)534-1750
On Thu, 2 Mar 2006, Fernando Simon wrote:
> Hi Michael,
> For 9i version you can use the VERSION parameter in your layer DATA
> definition, in your case:
> DATA "SHAPE FROM SITE USING UNIQUE SITE_ID SRID 8307 RELATE VERSION
> 9i"
> Best regards.
> Fernando Simon
> Mapserver and Oracle Spatial developer
> G10 - Laboratorio de Computacao Aplicada - Brazil
> http://www.univali.br/g10 - UNIVALI/CTTMAR
> Michael Scharber wrote:
>> Hi There,
>> How exactly does one get MapServer to play with Geodetic data (SRID=8307)
>> in Oracle Spatial (9i)? I cannot get past:
>>> "Element of type Extent is not supported for Geodetic data"
>>> msDrawMap(): Image handling error. Failed to draw layer named 'gps'.
>>> msOracleSpatialLayerWhichShapes(): OracleSpatial error. Error: ORA-29902:
>>> error in executing ODCIIndexStart() routine ORA-13373: Element of type
>>> Extent is not supported for Geodetic data ORA-06512: at
>>> "MDSYS.SDO_INDEX_METHOD_9I", line 368 ORA-06512: at line 1 . Query
>>> statement: SELECT SITE_ID, SHAPE FROM SITE WHERE SDO_RELATE( SHAPE,
>>> MDSYS.SDO_GEOMETRY(2003, 8307,
>>> NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-8.94375,36.73125,13.55625,59.23125)
>>> ),'mask=anyinteract querytype=window') = 'TRUE' . Check your data
>>> statement
>> For example, in other applications (Java, Perl, etc) I use the following
>> with success:
>> select site_code,site_name from site where
>> SDO_RELATE(shape,MDSYS.SDO_GEOMETRY(2003,8307,null,
>> MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,1),
>> MDSYS.SDO_ORDINATE_ARRAY(-118.0,32.0,-116.0,32.0,-116.0,35.0,-118.0,35.0,-118.0,32.0)),
>> 'mask=inside querytype=WINDOW') = 'TRUE'
>> My MapServer config parameters are:
>> CONNECTIONTYPE oraclespatial
>> DATA "SHAPE FROM SITE USING UNIQUE SITE_ID SRID 8307 RELATE"
>> Any suggestions?
>> Thanks in advance.
>> Michael
