threads in mapserv
Frank Warmerdam
warmerdam at POBOX.COM
Thu Mar 2 23:58:02 EST 2006
tim wrote:
> Hi,
> the unix compile howto at
> http://mapserver.gis.umn.edu/docs/howto/compiling_on_unix
> gives as an example ./configure --with-threads (as one of many options)
> however the thread safe faq
> http://mapserver.gis.umn.edu/docs/faq/thread_safety
> says mapserver is /not/ thread safe. Does this mean that the
> --thread-safe switch should not normally be used or am I not seeing
> something obvious here? If so perhaps it should be noted in the howto.
Tim,
The thread-safe faq question goes on to explain that mapserver likely
can be used safely in some contexts. The --with-threads switch basically
turns on mutex locking for various components. In many cases (ie. GDAL)
this amounts to a BigLock(tm) around the whole subsystem substantially
limiting the amount of benefit from multi-threading. But at least it
keeps things known to be problematic working pretty safely.
The --with-threads switch does not need to be used in normal cgi or
single threaded mapscript use. It does add a modest overhead. It
should be used in any situations where you think multiple threads might
be going through mapserver code at the same time.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
