threads in mapserv
Frank Warmerdam
warmerdam at POBOX.COM
Fri Mar 3 09:11:47 EST 2006
chris at narx.net wrote:
> 5. Built mapserv.fcgi with the following configuration
> ./configure --with-proj --with-ogr --with-gdal --with-wfs --with-wcs
> --with-wmsclient --with-wfsclient --with-sde-version=91
> --with-sde=/arcsdesdk/sdeexe91/lib/ --with-fastcgi=/WSPACE5/fcgi_bin
> [root at t2lin cgi-bin]# ./mapserv.fcgi -v
> MapServer version 4.6.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER INPUT=EPPL7 INPUT=SDE INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
Chris,
If MapServer isn't reporting SUPPORTS=FASTCGI then it did not get built in
successfully (link or not). What does the FastCGI section of Makefile look
like? It should read something like:
# Optional FastCGI
FASTCGI=-DUSE_FASTCGI
FASTCGI_INC=
FASTCGI_LIB=-lfcgi
I *suspect* you need to use --with-fastcgi=/WSPACES/fcgi-2.4.0.
I sympathize with the challenges of getting fastcgi support working. It
makes me appreciate how relatively easy it is to debug issues int he
traditional cgi mechanism.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
