MapServer incompatibility with RHEL4/CE NTOS4.2
Lowell.Filak lfilak at MEDINACO.ORG
Fri Mar 3 12:49:25 EST 2006
Doyon, Jean-Francois writes:
> OK, we're running 32 bit CentOS 4.2, on Xeon processors.
> I'm thinking there's some problem with the newer glibc or something like
> that, which would also explain the crashes I was having at first on a
> specific map?
> J.F.
J.F.,
I guess that takes the EM64T out of the equation.
Do you mean you actually compiled the version of mapserver you have on the
RHEL box against an older coy of GD and you're sure it's using the older
version of the libs at runtime?
Lowell
