MapServer incompatibility with RHEL4/CE NTOS4.2
Lowell.Filak
lfilak at MEDINACO.ORG
Fri Mar 3 13:33:05 EST 2006
Doyon, Jean-Francois writes:
> Correct, I never suspected the compiler. I suspect the mapserver code, for
> some reason, isn't interacting properly with glibc ...
> I'm going to try and explore the possibility of chrooting mapserver and
> linking it against a separate older glibc. CentOS comes with glibc 2.3.4
> ... If I can install/compile link mapserver and it's dependencies on CentOS
> against glibc 2.2.5 (the version from RH 7.3) ... Then that might give us a
> clue as to what the problem is. That's a fair emount of work though, so I'm
> going to revert back to my older servers for now :(
J.F.,
Sorry, typo. How do you know it's not the gd libs on the RHEL box causing
the problem (or even ft)? Is the version of gd on the 7.3 box the same as
the CentOS box?
Lowell
