MapServer on Linux
Tim Bowden
tim.bowden at WESTNET.COM.AU
Sun Mar 5 08:54:56 EST 2006
On Sun, 2006-03-05 at 14:12 +0100, Martin Krempl wrote:
> Hi,
> I'v got some problem with run MapServer on Linux. I completed
> installing of MapServere successfull. When I type in web browser
> *http://localhost/cgi-bin/mapserv
> *on the screen it will show *QUERY_STRING is set, but empty*. I know
> that's OK, test is successfull.
> But when I type
> http://localhost/cgi-bin/mapserv?map=myFirst.map on the screen I will
> see this error message: *
> fined.: Unable to access file. bel()*.
> This message will show everytime and doesn't matter if the file
> myFirst.map exists or not. Have anyone some idea how can I fix this bug.
> Thank you Martin
Martin, have you checked file ownership and permissions? Assuming you
are using apache and it runs as user apache, set the files owner to
apache:
chown apache:apache myFirst.map
HTH,
Tim Bowden
Mapforge Geospatial
Level 3/ 267 St Georges Tce
Perth 6000
Western Australia
