GetLegendGraphic and sld
Kralidis,Tom [Burlington] Tom.Kralidis at EC.GC.CA
Mon Mar 6 08:49:23 EST 2006
Worked!  Forgot about this one.  Thx
	-----Original Message-----
	From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
	Sent: Mon 06-Mar-06 08:44
	To: Kralidis,Tom [Burlington]
	Cc: MAPSERVER-USERS at LISTS.UMN.EDU
	Subject: Re: [UMN_MAPSERVER-USERS] GetLegendGraphic and sld
	Tom,
	  If you set the name parameter inside the rule, It will be used to set
	the class name on the layer. The class name is the one that is used as
	text in the legend. (Bug 1451 is realted to this).
	  Later,
	Kralidis,Tom [Burlington] wrote:
	> Hi,
	> Does MapServer's OGC:WMS GetLegendGraphic support changing of legend text in addition to the actual graphic mark?  We're able to do the latter via SLD, but we can't seem to change the legend text.
	> We're using latest CVS.
	> Test URL:
	> http://devgeo.cciw.ca/cgi-bin/mapserv/hydromet?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=hydromet_latest_water_levels&format=image/jpeg&sld=http://devgeo.cciw.ca/ms_tmp/kyw_sld.xml
	> Under the hood, the data from the OGC:WMS is a point layer, with the following CLASS block:
	>   CLASS
	>    NAME "Water Levels"
	>    SYMBOL 'circle'
	>    SIZE 3
	>    COLOR 0 0 255
	>   END
	> ...so I'm not sure whether something has to be enabled from the server end to enable the SLD to specify titles, or if the SLD is off.
	> Please advise.
	> Thanks
	> ..Tom
	Assefa Yewondwossen
	Software Analyst
	Email: assefa at dmsolutions.ca
	http://www.dmsolutions.ca/
	Phone: (613) 565-5056 (ext 14)
	Fax:   (613) 565-0925
