Tileindex of DGN's being opened as shapefilelayer
Delfos, Jacob
jacob.delfos at MAUNSELL.COM
Mon Mar 6 22:20:47 EST 2006
Hi Bart,
Thanks for letting me know, at least I know I'm not doing anything
wrong.
Sorry for the late reply. Public holiday and all......
Regards,
Jacob
> -----Original Message-----
> From: Bart van den Eijnden (OSGIS) [mailto:bartvde at xs4all.nl]
> Sent: 3 March 2006 15:57
> To: Delfos, Jacob
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Tileindex of DGN's being
> Hi Jacob,
> I can only state that I have seen this problem as well myself with
> Mapinfo TAB files in a tileindex, I was also using them through
> PHP/Mapscript. In the end I used Mapinfo seamless layers to
> get around
> that, but that won't be an option for your DGN's.
> Best regards,
> Bart
> Delfos, Jacob wrote:
> > Hi,
> > Just to provide some additional information: the map
> displays fine in
> > mapserver, but not in php_mapscript. It appears that php_mapscript
> > assigns a shapefile connectiontype to this layer, causing
> it to try to
> > open the DGN's as shapefile. In the mapserver CGI, this doesn't
> > happen. Can anyone with a better understanding of the difference
> > between the two tell me what I can do to get around it?
> > regards,
> > Jacob
> > *From:* UMN MapServer Users List
> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On Behalf Of
> *Delfos, Jacob
> > *Sent:* 20 February 2006 15:00
> > *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> > *Subject:* [UMN_MAPSERVER-USERS] Tileindex of DGN's being opened
> > as shapefile layer
> > Hi All,
> > I'm having some trouble creating a tile-index of DGN's, using
> > php_mapscript (Chameleon). My tileindex is a shapefile. But I
> > think the layer should be treated as OGR, yet the connectiontype
> > seems to indicate it thinks it is a shapefile layer.
> According to
> > my PHP log, it tries to open it as a shapefile, which
> obviously fails:
> > [20-Feb-2006 14:45:49] PHP Warning: [MapServer Error]:
> > msDrawMap(): Failed to draw layer named 'DGNs'.
> > in C:\chameleon\htdocs\common\wrapper\drawmap.php on line 560
> > msTiledSHPOpenFile(): Unable to open a single tile to use as a
> > template in layer DGNs.
> > msSHPOpenFile(): (c:/data/hongkong/10nwb.dgn)
> > msSHPOpenFile(): (c:/data/hongkong/10nwa.dgn)
> > I based my layer definition on
> _http://mapserver.gis.umn.edu/docs/howto/ogr_howto/#tileindex-
> with-ogr_
> > LAYER
> > NAME "DGNs"
> > TYPE LINE
> > STYLEITEM "AUTO"
> > CONNECTIONTYPE OGR
> > TILEINDEX "dindex.shp,0"
> > STATUS ON
> > CLASS
> > COLOR 150 150 150
> > END
> > END
> > The DBF of the shapefile has 1 column, with these values:
> > location
> > C:\data\10nwa.dgn,0
> > C:\data\10nwb.dgn,0
> > I am using php_mapscript 4.6.1, with php 5.05. Can
> someone tell me
> > what I'm doing wrong?
> > Regards,
> > Jacob
> > *JACOB DELFOS
> > GIS ANALYST
> > *Maunsell Australia Pty Ltd
> > 629 Newcastle Street, Leederville, WA 6007
> > PO Box 81, Leederville, WA 6902
> > Western Australia
> > ABN 20 093 846 925
> > Tel + 61 8 9281 6185
> > Fax + 61 8 9281 6297
> > _jacob.delfos at maunsell.com_
> OSGIS, Open Source GIS
> http://www.osgis.nl
