Mapfile Expression NULL value
Emmanuel BELO
emmanuel.belo at MICROGIS.CH
Tue Mar 7 05:47:54 EST 2006
Hi Steve, thank you for your answer but with PostgreSQL/PostGIS it
doesn't work.
For now, the solution is to add a WHERE clause in the SQL statement:
WHERE tx_femme IS NOT NULL
best regards,
eb
Steve Lime wrote:
> It really depends on how your datastore coughs up the data. I don't believe
> there is a true NULL with DBF files but I may be wrong. You might try
> expressions like:
> EXPRESSION (not '[tx_femme]')
> EXPRESSION ('[tx_femme]' = '')
> Steve
>>>> Emmanuel BELO <emmanuel.belo at MICROGIS.CH> 03/06/06 9:11 AM >>>
> Hi,
> how do you handle NULL values from you database in your mapfile's
> expression?
> Example (NULL value for some tx_femme):
> CLASS
> EXPRESSION (([tx_femme] > 8) AND ([tx_femme] <= 15))
> NAME "8 - 15"
> STYLE
> COLOR 255 217 0
> END
> END
> I've tried:
> EXPRESSION ('[tx_femme]' = 'NULL')
> EXPRESSION /_always_false_/
> Best regards,
> Emmanuel BELO
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060307/ba411d3c/emmanuel.belo.vcf
