C# mapscript...
John Cole john.cole at UAI.COM
Tue Mar 7 11:07:41 EST 2006
Howard,
  I'm trying to get your 4.8.1 build (thank you for making that) to work
with IIS.  Searching the website, there isn't a guide on setting this up.
I've gotten IIS to work with MS4W before, but I'm getting a 502 when I try
to hit this version.
  Mapserv -v returns the following:
C:\Inetpub\cgi-bin>mapserv -v
MapServer version 4.8.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPO
RTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=SDE INPUT=POSTGIS INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
So I'm pretty sure it's ready to go, and I've also made a decent stab at
getting the permissions correct.  Is there something that I've missed?
I'm on XP SP2 IIS 5
Thanks,
John Cole
-----Original Message-----
Sent: Monday, March 06, 2006 9:53 AM
To: John Cole; MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: C# mapscript...
John,
Grab the build kit.  All of the dependencies have been built
already.  All you have to worry about are gdal and mapserver.
<http://hobu.stat.iastate.edu/mapserver/build_output/mapserver-4.8-msvc71-bu
ild-kit.zip>
Make sure to edit nmake.opt for GDAL and make a clean GDAL (and then
do nmake /f makefile.vc install).  Edit nmake.opt for MapServer, make
clean, and make install for MapServer and you should end up with a
csharp directory in ..\bin with the C# mapscript binaries.
Catch me on IRC if you have questions.  Then we can write a doc ;)
Howard
At 09:42 AM 3/6/2006, John Cole wrote:
>Tamas,
>   Thanks for your help, some more questions now :-)
>   I've switched to the nightly.tar.gz (because I couldn't figure out flex
>and bison) but I'm having trouble with libpng.  I've checked their site and
>there isn't a lot of info on building with windows, much less building in
>VC8, how did you do it?  I'm getting the following error trying to build
the
>libpng solution
>Error   1       fatal error A1000: cannot open file :
>c:\projects\zlib\contrib\masmx86\inffas32.asm   MASM
>I have the zlib library but that file doesn't exist in it (nor does the
>masmx86 directory).
>   Also, I was the nmake /F Makefile.vc was getting errors on not finding
>bgd_i.lib, so I changed those references to bgd.lib, is that OK?  (it got
>past that).
>Thanks,
>John Cole
>From: Tamas Szekeres [mailto:szekeres.tamas at FREEMAIL.HU]
>Sent: Friday, March 03, 2006 3:58 PM
>To: MAPSERVER-USERS at LISTS.UMN.EDU; John Cole
>John,
>The parser and lexer files are not precompiled with the CVS version. You
>have at least 2 options to do:
>1. Use the nightly build instead containing theese files precompiled
>http://cvs.gis.umn.edu/dist/nightly.tar.gz
>2. Download flex and bison
>gnuwin32.sourceforge.net/packages/flex.htm
>gnuwin32.sourceforge.net/packages/bison.htm
>and generate theese files from mapparser.y and maplexer.l
>Best Regards,
>Tamas
