Double labels
Steve Lime
steve.lime at DNR.STATE.MN.US
Tue Mar 7 12:35:20 EST 2006
Not knowing exactly how Cartoweb works I wonder if you can test outside of it using shp2img?
Also, could you post:
- a sample image showing the doubling?
- a mapfile snippet for the layer in question?
Steve
>>> Giorgio Plazzotta <giorgio.plazzotta at SARASRICERCHE.IT> 03/07/06 6:26 AM >>>
Hello
I am using the Cartoweb middleware based on the Mapserver engine. After the reinstallation of the new version I am facing a problem of duplicate labels that didn't happen before using the same Mapfile.
Between the two versions (Cartoweb 3.1 and Cartoweb 3.2) the Apache was changed from 1.3.x fo 2.0.x and the php_mapscript.dll changed from 4.6 to 4.8. The OS is Windows 2000 pro.
After some investigation I relized that the problem applied on those labels using the WRAP function. When the text was splitted into 2 lines it was also doubled. Another strange thing is that if the LABEL section of the Mapfile contains the BACKGROUNDCOLOR the label is not doubled.
In the same installation i also tried to use a different mapfile provided in the Cartoweb samples and also in this case the labels are doubled.
Any idea?
Thanx
Giorgio
